Old 05-06-2021, 11:03 PM   #1
Gezer
Gezer's Avatar
Thumbs down 51 EAB Flathead Gas Leak
Stock Ford carb. on an EAB flathead. Can't tell exactly, appears to leak in or near the Accelerator pump. If so, is this an easy repair or should I have the carb rebuilt?
thank for your help.
Gezer is offline   Reply With Quote
Old 05-07-2021, 10:04 PM   #2
Ross F-1
Ross F-1's Avatar
Default Re: 51 EAB Flathead Gas Leak
First thing I'd check is the float level, probably too high.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 05-08-2021, 08:48 PM   #3
Gezer
Gezer's Avatar
Thanks Ross F-1. I will check it out.
Can you confirm that the carb is correct for the engine? One side of the carb has "FORD" on it and the other side has "ECG" on it.
5
At first I thought the was a truck EAB engine but after seeing some more stats I think it could be a Merc?????? The oil pan seams to look like a Merc
Thanks
Old 05-09-2021, 03:06 PM   #4
Ross F-1
Ross F-1's Avatar
Don't be fooled by external parts. My truck came to me with a Merc oil pan. From the paint I guessed it could be a Merc, but subsequent internal investigation proved it was a Car EAB that somewhere along the way got a Merc pan. I think that was common thing to do to eliminate the leaky clean-out plate on the truck pans.
I don't believe ECG carbs were ever stock on trucks, I believe that is a later Car carb, but has greater flow so a real upgrade. It is the same basic carb, just "grown" in the throttle plates and venturis for Y-block engines' greater HP. It should have a Loadamatic port and a "spark valve" on the throttle section (looks like a power valve, but isn't).
