09-17-2017, 01:23 AM | #1 |
My steering box blew up!
Ok. Not entirely accurate, however the lower bearing burst out the bottom end of the box... and now I have a 64 Galaxie that is no longer a daily driver.
Can I just get a new bearing, set it in place, then tap the cap back on? I didn't see anything that would make me think there's a snap ring for it. I have no experience with steering boxes aside from (apparently) making that deadly sector shaft adjustment several months ago. My budget is tight. I'd rather not have to buy a new box, but I suppose I must do what I must. Box tag says "HCA AX 4325C" and I'm not positive what that translates into. I do NOT have power steering and am satisfied with that. The manual steering suits me fine. If there's a modern replacement that wouldn't need the whole column replaced, I'd look into that. Give me part numbers if you have them. Sources for the parts are even better. Or if there's a used box in decent condition in your shop, I'd be interested as well. I'm leery of used boxes on eBay... unless someone can convince me otherwise. Please help me, FordBarn. You're my only hope.
Current Classics: 1930 Ford Model A Tudor 1937 Plymouth P4 Deluxe 2-door touring sedan 1964 Ford Galaxie 500 Past Classics: Early '30 Ford Model AA 1948 Dodge Deluxe 4-door sedan 1951 Studebaker Champion 2-door sedan 1988 Ford E-350XL Ambulance |
09-17-2017, 09:24 AM | #2 |
Re: My steering box blew up!
I suggest replacing the box. RockAuto has rebuilt ones on a core basis. Or you could send yours to Lares Manufacturing for a rebuild or exchange. They do the rebuilding for RockAuto.
http://www.rockauto.com/en/catalog/f...earing,1000226 |
09-17-2017, 10:52 AM | #3 |
Does it have a soft plug there or is it just a light press fit cap? The worm shaft should have some form of thrust control inside there so that it won't put too much pressure on that spot.
09-18-2017, 03:22 AM | #4 |
It appears to be a light press cap.
09-21-2017, 03:56 PM | #5 |
You are close enough to Lares to drive it there. They are in Cambridge, hwy 65 north of the Twitties.
09-21-2017, 06:42 PM | #6 |
I'd be concerned that the bearing seat is bad in the housing or something like that. If that is the case, you would need a good replacement housing anyway. Now if the cap was just loose in the housing then you just need to find a way to tighten it up so it stays in there and hopefully not too much crud got inside. |
09-22-2017, 02:34 AM | #7 |
I found another box at a junkyard. All is well! Now to make sure the oil is filled all the way. I've been busy day and night all week. Where do I check/fill? I've heard to use SAE 90 or straight STP. I have 90 on hand, so that was my plan.
I'm going to work on fixing the old box during the winter... gain an education that way.
09-22-2017, 06:09 AM | #8 |
The third pic you posted shows a "plug" by itself next to the sector arm cover. That " plug" is actually a vent and fill plug for your steering box. Fill it here until the lube just weeps out the hole.
Dan Kingman Az. 86409 |
09-22-2017, 08:29 AM | #9 |
If the lower seal is good, any brand SAE 90 or 85W/140 will stay in there. If they leak, the John Deere corn head grease works well. STP is some pretty viscous stuff (viscosity builder) so it would be about as easy to put in there as corn head grease but the corn head thixotropic grease is a better lubricant for the long term.
