09-03-2020, 07:19 PM | #1 |
brake drums
i purchased 4 new American made brake drums for my 40 coupe
the fronts fit fine the rear will not slide over the brake shoes i adjusted the brakes to minimal the lower shoe cams are adjusting if i remove the e brake vertical lever the drums will fit over the shoes what am i missing what am i not doing thanks gerry |
09-03-2020, 07:23 PM | #2 |
Re: brake drums
Could be several things, for one, if they are new shoes (not original ones relined) some have the holes at the bottom miss located. Also, where the shoes arced to match the drums?
09-03-2020, 07:27 PM | #3 |
Re: brake drums
When I replaced my shoes several years ago the drums wouldn't fit. Turned out the company that manufactured the shoes assumed that everyones drums would be at least .030 out, mine were NOS. Sent them back and had them tuned. They went right on.
Charlie Stephens |
09-03-2020, 07:54 PM | #4 |
Re: brake drums
i did not replace the brake shoes the reason for replacing the drums
the hubs and drums were drilled to chevy bolt pattern so i installed ford hubs 5 on 5.5 and purchased new drums could very well be the shoe arch thanks you gerry |
09-03-2020, 08:23 PM | #5 |
Re: brake drums
If you can tell how much of an interference you have between the shoes and the drums you might be able to fix it yourself. Use a strip of sandpaper inside the drum and sand the shoe to match the drum. If it is a small amount, easy to do. If it is a lot, not so much. Also, be sure to chamfer the ends of the shoes.
09-04-2020, 05:57 AM | #6 |
Re: brake drums
It's funny for it my rear brakes as well that had the issue. |
09-04-2020, 06:39 AM | #7 |
Re: brake drums
the brake drum will not slide over the rear brake shoes unless i remove the parking brake horizontal lever with the lever removed the drum fits freely im thinking of modifying the parking brake lever
09-04-2020, 07:07 AM | #8 |
Re: brake drums
could be the emergency brake cable adjusted to tight holding shoes out?
09-04-2020, 08:55 AM | #9 |
Re: brake drums
The emergency brake cable can be adjusted at the handle and also under the car near "X" member. When installing new shoes, you do also re-adjust the E cable.
09-04-2020, 07:01 PM | #10 |
Re: brake drums
even though i had play in the e brake cable i removed the cable from the vertical e brake lever the drum would not fit
i removed the horizontal e brake lever lengthen the pivot area of the two levers it worked kicked my ass i thank all of you for your replies to my post gerry |
