Old 05-03-2020, 10:09 AM   #1
hudson32700
Default Front engine mount
Why was the brass washer at the bottom of the front engine mount replaced by a flat washer and when?
hudson32700 is offline   Reply With Quote
Old 05-03-2020, 12:02 PM   #2
RB_Nielsen
RB_Nielsen's Avatar
Default Re: Front engine mount
I just replaced the front motor mount that had "just the washer" installed, and the center bolt was about worn in half. The washer did not appear to do the job that the new brass bushing I used to replace the plain washer might do.
RB_Nielsen is offline   Reply With Quote
Old 05-03-2020, 12:06 PM   #3
john charlton
john charlton's Avatar
The flat washer allows lateral movement of the front motor mount frame flexing over rough roads etc etc . The brass washer had a step which entered the cross member thus restricting sideways movement . Look in the Service Bulletins that will tell you when the change occured
John in Suffolk County England .
john charlton is offline   Reply With Quote
Old 05-03-2020, 12:10 PM   #4
Ernie Vitucci
John has built Model 'A's from a bare frame to a complete machine...when no two parts had even met before...He knows! Ernie in Arizona
Ernie Vitucci is offline   Reply With Quote
Old 05-04-2020, 11:19 AM   #5
Bob Bidonde
Bob Bidonde's Avatar
The brass bushing was replaced in production about January of 1929 because it was thought to restrict lateral motion of the engine, thus transferring vibrations into the frame.
Bob Bidonde
Old 05-04-2020, 11:24 AM   #6
The Master Cylinder
The Master Cylinder's Avatar
This from Bratton's catalog "The brass washer was used from Nov. '28 thru Jan. '29 then it was replaced with a steel flat washer. It is believed the brass shouldered washer restricted the yoke stud from moving side-to-side when one wheel went into a pothole, thus putting too much stress on the stud."
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 05-04-2020, 05:50 PM   #7
hudson32700
Thanks to all for the information.
Thread Tools
Display Modes
