Old 08-22-2010, 02:11 PM   #1
32Gnu
32Gnu's Avatar
Default Penny in my block
Does anyone know why there would be a penny in the block below the intake?
32Gnu is offline   Reply With Quote
Old 08-22-2010, 02:15 PM   #2
32Gnu
32Gnu's Avatar
Default Re: Penny in my block
1951 8ba by the way.....thanks
Old 08-22-2010, 02:16 PM   #3
ken ct
Someone wanted to block off the exhaust pasage under the carb. Theres usually 2 of them as the passage runs crossways between the 2 sides,should be one more on the oposite side. You must use the old all copper ones not the copper clad.ken ct.
ken ct is offline   Reply With Quote
Old 08-22-2010, 03:20 PM   #4
Jack E/NJ
Jack E/NJ's Avatar
As someone mentioned a while ago, rather than copper pennies, you can also easily insert (or remove) thin metal flatstock (such as aluminum, copper or steel roof flashing) to block off the passages after loosening the intake bolts a bit.
Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 08-22-2010, 03:28 PM   #5
jerry grayson
This makes the dual exhaust system louder. Old 1940-50 trick.
jerry grayson is offline   Reply With Quote
Old 08-22-2010, 03:29 PM   #6
ken ct
Jack E/NJ
Personally i think you would end up with a leak there [vacume] ?? ken ct.
Old 08-22-2010, 03:37 PM   #7
G.M.
You shouldn't get a leak with 18 gauge or thinner metal. In the fall when it gets a little crisp at night the duals really rap when you back off the gas pedal but it makes the carb. cold and don't want to run as good and needs choking until it gets hot. G.M.
www.fordcollector.com
Old 08-22-2010, 05:12 PM   #8
imnezrider
imnezrider's Avatar
I loved the sound in this as a high school kid in the 1950's. Went back and forth at will.....
imnezrider is offline   Reply With Quote
Old 08-22-2010, 05:31 PM   #9
denverslim
denverslim's Avatar
Flattie folklore. Ya gotta find a penny the same year as yer car, put it in the exhaust hole under each head. Abes head to the top. Gives yer car good luck and great sound...slim
denverslim is offline   Reply With Quote
Old 08-22-2010, 05:51 PM   #10
32Gnu
32Gnu's Avatar
Should I pop it out and check the year? LOL
What year did they stop using copper?
Old 08-22-2010, 06:02 PM   #11
Jack E/NJ
Jack E/NJ's Avatar
go to http://en.wikipedia.org/wiki/Penny_(United_States_coin)
Jack E/NJ
Old 08-22-2010, 06:09 PM   #12
flathead4rd
flathead4rd's Avatar
I think pennys prior to 1984 were solid copper.
flathead4rd is offline   Reply With Quote
Old 08-22-2010, 06:17 PM   #13
FL&WVMIKE
FL&WVMIKE's Avatar
On the last one that I helped with, a penny was too small and wanted to fall through. The hole in the gasket was just a tad smaller than a nickel, so we trimmed a couple of nickels and they fit perfectly ! It cost just a little bit more.
MIKE
FL&WVMIKE is offline   Reply With Quote
Old 08-22-2010, 06:20 PM   #14
Ross in East Texas
Ross in East Texas's Avatar
Send a message via AIM to Ross in East Texas
MIKE
That durned inflation!
Ross Murphy
1939 Ford Standard Coupe
Ross in East Texas is offline   Reply With Quote
Old 08-22-2010, 06:20 PM   #15
lonewolf
hope its a 1909 s v.d.b.
lonewolf is offline   Reply With Quote
Old 08-22-2010, 06:24 PM   #16
G.M.
We used to go into Philadephia at about midnight on Friday and wind up in first down those narrow streets with row houses on each side and let the duals with the heat risers blocked back down thinking we could break windows like a high pitched opera singer. The lights in the houses started going on and we got out of there fast. G.M.
Old 08-22-2010, 06:47 PM   #17
Tom/SC
Tom/SC's Avatar
Those pennies in the manifold also gave the flathead with duals a good "fluttering "sound when you took off from the stoplight. I had to open the hood on my 40 many times to prove that I was not running a Cadillac or Olds engine. When you wound it up it really rattled the pipes. Tom
Tom/SC is offline   Reply With Quote
Old 08-22-2010, 07:02 PM   #18
[email protected]
I used to love driving down the streets in my hometown of Grand Rapids Mn. There were block buildings on both sides of the street that trapped the sound and rapping the pipe was fun. We had about 4 blocks like this and I'd love to crank that old flatty up and just as I cleared the light let up on it. Even in the winter I'd roll my window down so I could hear those pipes. And I'm not the only one who did it. Another thing we thought was cool was when two guys would line up and let em go when the light went green. These guys would race for $20 between lights and it use to sound so great. Though I always wanted to race I never had the money to do it. God I want to go back to those nights just for one night.
garrisonm89@yahoo.com is offline   Reply With Quote
Old 08-22-2010, 08:15 PM   #19
ford1
now to answer your question, they are there to plug the crosser over heat riser for the carb, like a modern heat riser they cause the carb to warm up faster and run better, the cross over is usually plugged any way with carbon and dont work, any way a flat head head doesnt need any more heat at the carb, it gets hot enough with out that cross over passage, with the passage open it tends to cause the carb to get so hot the gas is boiled out of carb and flooding the engine, one cause of hard hot engine restarting
ford1 is offline   Reply With Quote
Old 08-22-2010, 08:26 PM   #20
billwill
Smile Re: Penny in my block
Jack E/NJ
where in new jersey
billwill is offline   Reply With Quote
