02-23-2011, 06:21 AM | #21 |
Re: how to keep fenders form re-cracking on a 36 pickup
Contact: [email protected]
He makes patch panels for cars that might work for trucks. He hand forms them on a buck. For some flexibility you can fiberglass in a copper or steel tube bent to the shape of the fender. spreads the stress out over a wider area. Fat Fenders Forever |
02-23-2011, 09:43 AM | #22 |
I think you might be thinking of the ESAB wire...called EZ weld I think?
02-23-2011, 10:01 AM | #23 | |
02-23-2011, 12:14 PM | #24 |
Do you, by chance, have a Bead Roller? With a tipping wheel on a Bead roller you could easily create the Panels you posted-otherwise, I would make them with a wooden buck-
02-23-2011, 12:51 PM | #25 |
ted ill take all the peaces you cut off your fine ford
02-23-2011, 01:21 PM | #26 |
No guarantee that I could make it good enough or quick enough but it is worth a try. |
02-23-2011, 02:12 PM | #27 |
cool hand that looks good
02-23-2011, 02:41 PM | #28 |
On my 40, I had some small cracks on the lip. I sandblasted the area then welded a length of rod in for support. I then filled and shaped some heavy roofing tar paste into the lip so that water cannot stand and collect wet dirt or the fine chemicals we get on our winter roads.
Just my .02's worth. Fourdy |
02-23-2011, 03:40 PM | #29 | ||
Now you have me on option 4 or is it 5 and I am skipping right to it! got to put that 40 ton ironworker to use..... Last edited by Steel 35; 02-23-2011 at 04:46 PM. |
02-23-2011, 11:49 PM | #30 |
I have not watched a bead roller before tonight looking up the tipping wheels, looks like another project coming on! I need to have my internet shut off. Now I started on a die, had already cut a wooden pattern, and just got the shrinker / stretcher That one is out for this project but I did give the wooden pattern a test slap tonight the wood failed, but looks promising, Still need to roll a bead but this should make a good practice piece for that as well. I should have this piece done by Monday just don't know what month.........
02-25-2011, 03:53 AM | #31 |
Yes Gerald shes a nice three window
02-25-2011, 04:59 AM | #32 | |
Twice Pipes C.C. |
02-26-2011, 11:37 AM | #33 |
After experimenting I realise the advice I gave is not going to work, because there is a bead around the edge ,A bead/ swagger roller is likely a good investment specially if you want to do more cars .The bit about the tree stump instead of a English wheel is relevant .
02-26-2011, 12:32 PM | #34 |
KWMPA,
Thanks for the info. Fortunately I used a small amount at the rear of the fenders. Reminds me of the saying - Too soon old, too late smart. LOL Fourdy |
02-26-2011, 10:07 PM | #35 |
My patch for the day and it was a long one! Picture #4 was my first bead roll test but oh did I find some lead it that old girl...........
02-26-2011, 10:13 PM | #36 |
Way to go Steel 35. Nice job!
02-27-2011, 05:39 PM | #37 |
Bubba fix. Hammer and dolly the crack back into shape. Drill out the end of the crack just like in a block and use a grinder with a metal cutting wheel to widen the gap in the crack. Cut a strip of 18 ga. (thinnest I usually keep around) about 1" wide and a little longer than the crack. From the backside hammerform it to the shape of the crack. I usually hold this piece in place with a clamp or long reach vice grips. Where there is good contact between the bandaid strip and the two sides of the crack, spot weld ACROSS from one side of the fender to the other. Now you've got the two sides of the crack connected plus a backing thickness of fresh steel. Hammering and moving the clamps for a tight fit as you go, stitch weld across like before. Soon the crack is welded and backed.
Welding across leaves a minimum of slag or unburnt wire stuck in the joint. When the crack is full, you can either turn the fender upside down and weld the edges of the bandaid 18 ga. to the fender or drill holes from the top, hammer, and fill with a rosette. (You may want to drill and clean the holes from the top in advance if you know this is what you'll need to do.) The purpose is to distribute the stress of the crack into a wider area. I do a lot of this professionally (not on cars; don't ask). If neatness is a criteria on the inside you can grind and undercoat the patch. This may not be for Pebble Beach but, then again, Pebble Beach ain't for me. |
04-02-2011, 11:06 AM | #38 |
Couple more bolts and some paint on the rear bracket's, then its just detail's
04-02-2011, 11:43 AM | #39 |
Nice job on the repair, thanks for showing the improvised bead roller in the lathe - I have a lathe and I never thought of that before.
Mart. |
04-02-2011, 07:40 PM | #40 |
