12-02-2013, 07:40 PM | #11 |
Re: Model A motor froze-up
Drain the water or add anti-freeze, but I'd recommend the draining. No need to drain the oil, but a good idea to replace it with new fresh oil before storing for the winter. After you do this, turn the engine over a few times to splash the oil around (don't have to start it). Also pour a couple tablespoons down each spark plug hole. Put the plugs back in. Put a note on your windshield reminding yourself that the car has no water in it. It's easy to forget come springtime when you're anxious for your first drive.
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. Last edited by 700rpm; 12-02-2013 at 07:45 PM. |
