02-24-2023, 06:35 PM | #1 |
Gas drip
I bought a new gas tank valve from one of the suppliers. "Guaranteed not to leak." Leaked like a sieve.
Put the older one back in. Drips once in about two minutes. I am thinking about putting a second valve in the line under the hood. I store the car for a few months each year. Anyone has suggestions on a valve? With the present set up, if I do not run the carb dry, it does not seem to leak. If I run it dry when shutting it off, it eventually leaks. Thanks for comments. |
02-24-2023, 06:45 PM | #2 | |
Re: Gas drip
I finally put in a second valve and have not looked back since. Bratton's sell something similar. https://www.brattons.com/30-31GAS-LI...uctinfo/13350/ Last edited by Y-Blockhead; 02-26-2023 at 03:12 PM. |
02-24-2023, 07:46 PM | #3 |
Re: Gas drip
Drain the tank. Take the valve apart and smear some EZ Turn on the turning part. Re assemble the valve. You will be amazed at how easy it turns and it will not leak. The valve will last a lot longer. In a few years do it again as part of your maintenance program.
See https://www.aircraftspruce.com/catal...ezturnlube.php
02-24-2023, 08:29 PM | #4 |
Re: Gas drip
I put a compression fitting shut off valve on the fuel line from the fuel filter to the carburetor. Mount the valve with the handle toward the firewall. That is so you will not hit it with an appendage, it can hurt.
Bill Cilker, Jr Unrestored 190A Victoria 45B, 160B & 189A Victoria Association President |
02-24-2023, 09:01 PM | #5 |
Re: Gas drip
When faced with the same issue, I used a 1/4-turn ball valve from Home Depot; been working great for a few years now. This replaced a previous solenoid-operated cutoff installed by a previous owner - when those fail, they default to off (I found that out the hard way one day while taking a drive).
I decided to put it PAST the sediment bowl, on the assumption that any fuel getting to it will be filtered, and thus less likely to contain particles/contaminants that could cause damage (notice also that I put in a Wix #33039 filter in the sediment bowl). |
02-24-2023, 09:31 PM | #6 | |
Re: Gas drip
02-24-2023, 09:34 PM | #7 |
Re: Gas drip
Did you return the faulty valve to the supplier ? Wayne
02-24-2023, 10:48 PM | #8 |
Re: Gas drip
Renners corner builds a lot of after market shutoff valves, I have had a lot of success with their p[roducts.
02-25-2023, 08:05 AM | #9 |
Re: Gas drip
I would ask supplier for a replacement.
02-25-2023, 08:56 AM | #10 |
Re: Gas drip
I bought a repair kit for the fuel valve on my early ’28 OCPU from Snyder’s some decades ago. It had an original valve which was frozen stiff. I followed the directions and used EZ Turn like nkaminar suggested and it is still easy to turn and has never leaked. My ’28 roadster came with a repro valve which was hard to turn and leaked. I replaced that with several other repros but they never lasted very long until they started leaking. The last one I bought from Snyder’s about 2 years ago still turns easily and doesn’t leak. Maybe I'm just lucky now.
02-25-2023, 09:27 AM | #11 |
Re: Gas drip
Compression fitting accessory valves run the gamut. Swagelock is probably the best (nuclear qualified) but pricey. Go to HD or Lowes and you're pretty much guaranteed run of China's mill.
I like the idea of a "quarter turn" ball type valve rather than a needle or T-valve. Joe K
Shudda kept the horse. Last edited by Joe K; 02-25-2023 at 09:42 AM. |
02-26-2023, 01:57 PM | #12 |
Re: Gas drip
The first thing I visualized from this was a leak to the outside of the valve so it took a while to get that is was leaking past the valve down into the line was the issue here.
The EZ-Turn prevents galling from metal on metal parts like the old valve designs and it can fill in imperfections in the seating surfaces. The other problem is corrosion from inside the tank. Even with a pencil filter in there, some of the fine stuff will get by. Debris like this can scratch the valve faces and start a leak over time. |
02-26-2023, 02:52 PM | #13 |
Re: Gas drip
I’ve been using these for years on all my Model A,s and not a drop gets past this valve…others will say that it’s a bandaid but it definitely works for me. I get mine from Ace Hardware….
02-26-2023, 05:52 PM | #14 |
Re: Gas drip
yes
02-26-2023, 05:54 PM | #15 |
Re: Gas drip
Asked for refund. No confidence another one will be any better.
03-01-2023, 05:51 PM | #16 | |
Re: Gas drip
