Old 05-18-2022, 05:57 PM   #1
whizzernick
whizzernick's Avatar
Default 1934 victoria
can the fuel tank be remover without lifting body ???
whizzernick is offline   Reply With Quote
Old 05-19-2022, 04:19 PM   #2
jimTN
Default Re: 1934 victoria
I'm not sure about the vicky but you can remove the tank from a regular sedan. Tight fit but will come out.
jimTN is offline   Reply With Quote
Old 05-19-2022, 05:30 PM   #3
mercman from oz
mercman from oz's Avatar
Rear Shot of a 1933 Ford Victoria. Notice that the 1933 Ford Victoria has a similar Panel covering the Fuel Tank like the other 1933 Fords.
Old 05-19-2022, 05:33 PM   #4
mercman from oz
Rear Shot of a 1934 Ford Victoria. Unlike the 1933 Ford Victoria, notice that on the 1934 Ford Victoria, that opening Lid goes all the way down to the bottom with no removable Panel. I believe that it would be impossible to remove the Fuel Tank on a 1934 Ford Victoria.
Old 05-19-2022, 06:06 PM   #5
mercman from oz
Close up shot of 1933 Ford Victoria showing rear cover panel similar to the other 1933 Fords.
Old 05-19-2022, 06:08 PM   #6
mercman from oz
Close up shot of 1934 Ford Victoria rear showing how the Trunk Lid extends all the way to the bottom, making it impossible to remove the Fuel Tank.
Old 05-19-2022, 08:15 PM   #7
deuce_roadster
deuce_roadster's Avatar
The 33 used in the comparison is a super early "skirtless" car.
Old 05-19-2022, 08:59 PM   #8
mercman from oz
Good spotting deuce_roadster.
This car was on display at the 2013 Grand Nationals at Lake Tahoe.
Old 05-19-2022, 09:04 PM   #9
mercman from oz
Close up of the 1934 Ford Victoria with the Trunk Lid open.
There is no way the Fuel Tank could be removed on this body style.
Old 05-20-2022, 01:04 AM   #10
cas3
Hard to believe Henry would do that. I know the tanks are different, does it mount to the bottom of the frame so its removable? never seen one up close
Old 05-20-2022, 01:27 AM   #11
deuce lover
deuce lover's Avatar
Mounts on top the frame.They have a different spreader bar than the conventional '34 .The tanks are same as for the pickup.Have a removable collar fill tube.When I did my Vicky in 1970 I had the body off so tank removable was easy.
deuce lover is offline   Reply With Quote
Old 05-20-2022, 02:33 AM   #12
mercman from oz
deuce lover's 1934 Ford Victoria
Old 05-20-2022, 04:30 AM   #13
mercman from oz
Here is a front view of that Early Production 1933 Ford Victoria with "skirt-less" Fenders. Photo taken at Lake Tahoe in 2013
Old 05-20-2022, 05:16 AM   #14
mercman from oz
Different location of Fuel Filler Neck on 1934 Ford Victoria
Old 05-20-2022, 10:18 AM   #15
deuce_roadster
The 34 Victoria filler neck screws into the tank like the pickup one. There is a thick lead washer that makes the seal. I don't know if this would make the tank harder or easier to remove. Might be able to move it sideways and drop one end down.
My 34 sedan delivery had the same kind of tank with a screw in filler pipe. Might even have been the same tank, I never looked up the part number.
Old 05-27-2022, 03:59 PM   #16
Colin James
What would be the most practical way to lift the body on a Vicky in order the replace the gas tank?
Colin James is offline   Reply With Quote
Old 05-27-2022, 05:54 PM   #17
McCready
McCready's Avatar
Send a message via MSN to McCready
Yes same all the same tank also fits delivery,woody,pickup not sure about filler necks I have a delivery one and pickup there slightly different.
McCready is offline   Reply With Quote
Old 05-28-2022, 10:19 AM   #18
TJ
TJ's Avatar
I would remove the filler neck. Then unbolt the tank and slide it to one side to see if the end will drop down to get it out. I would try that before trying to lift the body.
Old 05-28-2022, 03:11 PM   #19
Leadfoot4U
Leadfoot4U's Avatar
That won't work, the tank itself just barely fits between the frame rails....there's no end play left or right.
With the tank side flanges on top of the frame, remove the two stationary bolts on the passenger side.....one spring loaded bolt on the left, you have to remove the rear spreader bar (which has the rear bumper mounts welded to it); raise the rear body with a hoist once the frame bolts are removed; then slide the tank down the rear frame horns, under the body apron that allows the bumper supports to go through. Five to six inches of height is needed to have the tank clear the rear body apron.
Yes, the filler neck must be unscrewed first, not to mention the air and fuel lines.
A chain fall COULD be used to raise the body by removing the two rear window interior garnishes, rolling down the windows and using a 4x4 with carpeting as cushioning to raise the rear of the body.
Leadfoot4U is offline   Reply With Quote
Old 05-28-2022, 10:27 PM   #20
V8COOPMAN
V8COOPMAN's Avatar
Just a suggestion for a much simpler method of raising the rear of the body a few inches. Coop/AMERICAN
Click Links Below __
T5 W/TORQUE TUBE
