Old 10-19-2020, 08:44 PM   #1
throwback
Default what are the differences between 1948 rear diff vs 1936 diff
Besides the hydraulic brakes what are the differences between a 1948 rear differential and a 1936 differential? I currently have a 1936 4.11 rear differential. The 1948 has a 3.78 gear ratio. I am contemplating a swap to improve the gear ratio.
Thanks for your input!
throwback is offline   Reply With Quote
Old 10-19-2020, 08:58 PM   #2
31Abone
31Abone's Avatar
Default Re: what are the differences between 1948 rear diff vs 1936 diff
from 11's to 78's only help a little with lots a cursing ..much better to go a 3.5 or 3.27..been thru this crap on a 32..in hind site wish i would have to a 3.27 instead of 3.54..21 stud v8
31Abone is offline   Reply With Quote
Old 10-19-2020, 10:04 PM   #3
Bursonaw
Bursonaw's Avatar
The 1948 3:78 gears are 6 spine on the pinion gear with a solid driveshaft. The 1936 pinion gear is 10 spline with a hallow driveshaft. You cannot use the 6 spine gears on the 36 unless you will cut drive shaft and weld a 6 spine coupler in place. You however can use 10 spline gears on you 48 with a 6 to 10 spline coupler. Personally I think your best bet is to find 10 spine gears in the ratio you want.
One thing to be aware of is that 1932-1934 ring and pinion gears are 10 spine but shorter than 1935-1948 gears and will not work for your application.
Sent from my iPad using Tapatalk
Bursonaw is online now   Reply With Quote
Old 10-20-2020, 12:04 AM   #4
V8COOPMAN
V8COOPMAN's Avatar
ANY Ford rear end with a 3.78 (or ANY ratio) gear set from '35 THRU 1940 complete with torque tube and drive shaft will bolt-in to your '36 chassis. The rears will all be equal in width, and the torque tubes/drive shafts are all the same dimensionally. Shouldn't be TOO difficult to find a '40 rear with a 3.78 floating-around out there. DD
T5 W/TORQUE TUBE
One thing you learn from history....is that nobody learns from history!
Old 10-20-2020, 10:24 AM   #5
Automotive Stud
Automotive Stud's Avatar
The '48 rear is wider also.
Automotive Stud is offline   Reply With Quote
Old 10-20-2020, 10:55 AM   #6
deuce lover
deuce lover's Avatar
Just my 2 cents. In 2010 I went to the V8 Club Western Nationals from Victorville,CA to St George UT. 36 5W ,59AB w/mild cam and 2 97's, 39 trans , 3.54's .6.50X16 rear tires Went over 2 mountain passes 70MPH all the way except for Las Vegas interchanges.Filled up Victorville going and St G coming back at StateLine in between going both ways.Averaged 12.5 MPG.Can't complain.The car had 3.78 originally.
deuce lover is offline   Reply With Quote
Old 10-20-2020, 11:31 AM   #7
blucar
blucar's Avatar
, The '48 differential is not a direct swap into a '36. The '48 is a longer wheel base car than the '36, therefore the torque tube is longer, additionally the '48 is 2" wider than the 36 and the brakes are hydraulic in lieu of mechanical.
The '48 axles, and axle housings will fit and work on a '36 center section, however, '37-'38 radius bars have to be used.
If you want to improve the gearing to 3.78, buy a new gear set in the ratio you want and have a good mechanic install it.
Bill.... 36 5 win cpe
Thread Tools
Display Modes
