Old 10-05-2019, 03:48 PM   #1
cajunfirehawk
cajunfirehawk's Avatar
Question taillight stand under fender bracket picture request
Need some help; on a 1936 ford 2 dr sedan model 68, the left or right taillight stand bracket that go under the fender, can someone post a clear picture showing how these go under the fender and help support the taillight stand
Cannot find a picture for reference, thanks as always.
(Michael's pic of said bracket for reference)
Regards,
Todd
1936 FORD Tudor Slantback
"cajunhotrodder" on instagram/youtube
cajunfirehawk is offline   Reply With Quote
Old 10-07-2019, 02:13 AM   #2
Randy in ca
Randy in ca's Avatar
Default Re: taillight stand under fender bracket picture request
Todd, I can take some pictures of how the under fender bracket attaches if you still need the information. The picture you posted doesn't show the 90 degree bend and 2nd. mounting hole that should be there - if it's not just hidden in the photo that bracket won't do the job.
Randy in ca is offline   Reply With Quote
Old 10-07-2019, 03:33 AM   #3
cajunfirehawk
Thumbs up Re: taillight stand under fender bracket picture request
Hi Randy,
No, I have to be honest, I went around about this several times and I cannot for the life of me figure why these are necessary best I can tell these mount like this under the fender, 2nd hole portion is hidden in this pic but without these brackets the light stands are rock solid as is so not sure I need them but i think they go like this? If My assumption is wrong and you have the time that would be very nice of you to take a few pics, thanks Randy!
(side shown is drivers side w/fuel filler neck)
Regards,
Todd
Old 10-07-2019, 07:37 AM   #4
deuce lover
deuce lover's Avatar
The single bolt hole on the flat attaches to the lower stud on the tail light stand.The bolt hole on the bent over tab lines up to a fender bolt to the body .The wire from the tail light goes in the reveal (bead) slot to be concealed.Probably only on the coupe or cabriolet it would matter for the rumble step to brace it better.If you don't want to see the wiring I would install them.
deuce lover is offline   Reply With Quote
Old 10-07-2019, 09:44 AM   #5
50droptop
Always thought they served a better purpose of protecting the wire loom vs bracing the taillight stand. As mentioned, the taillight stand is plenty solid without the support.
50droptop is offline   Reply With Quote
Old 10-07-2019, 10:39 AM   #6
Tom-MI
Tom-MI's Avatar
This should help.
Tom-MI is offline   Reply With Quote
Old 10-07-2019, 05:47 PM   #7
cajunfirehawk
THANK YOU Gentleman for the help, I'm sure these pics will help others too in the future!
Regards,
Todd
Old 10-11-2020, 07:05 AM   #8
zeroviz
are these also on 1935 ford coupes?
zeroviz is offline   Reply With Quote
Old 10-11-2020, 07:10 AM   #9
deuce lover
Yes and slightly different than '36
Thread Tools
Display Modes
