Old 02-03-2018, 05:10 PM   #1
Y-Blockhead
Y-Blockhead's Avatar
Default Tube Valve Stem Size
Does anyone happen to know the thread size for a inner tube valve stem cap? It is finer than 5/16-24. I see McMaster-Carr has 5/16-18, 20, 24, 27, 28, 32, 40 tpi. Not sure why there are so many different sizes in 5/16" threads.
I need to clean up the threads on a couple nickel valve caps.
Thanks
Old 02-03-2018, 06:11 PM   #2
Synchro909
Synchro909's Avatar
Default Re: Tube Valve Stem Size
Just went to the workshop and measured it for you - 32 tpi.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 02-03-2018, 07:47 PM   #3
Y-Blockhead
Awesome. Thanks Synchro. I'll order one up. I don't think the local Ace will have that size.
Looking at McMaster-Carr prices, I was hoping it was a 5/16-32 as opposed to a 5/16-28 (or another odd size). They want $8.07 for a 5/32 bottoming tap compared to $23.81 for a 27, 28 or 40!
Old 02-03-2018, 08:51 PM   #4
Synchro909
Synchro909's Avatar
No worries, Y.
32 tpi is probably cheaper exactly because it is so widely used on valve stems.
Old 02-03-2018, 11:03 PM   #5
160B
160B's Avatar
There is a valve stem tool available, it is very handy. I have several one for the shop and one in my roadside tool kit. Clears thread on valve stems
https://www.amazon.com/Pit-Posse-Rem...alve+stem+tool
https://www.amazon.com/Valve-Repair-...alve+stem+tool
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 02-04-2018, 02:52 AM   #6
redmodelt
redmodelt's Avatar
He is needing a tap to clean up his caps, not the valve stem.
