Old 01-26-2018, 05:20 PM   #1
oldredford
Default Thats it for me
Just lost another electronic module on my way to eat. Luckily I had a spare breaker point distributor all built up ready to go. Installed the distributor and fired right up. So much for modern reliable electronic ignition. Please don't tell me it was a bad ground....
oldredford is offline   Reply With Quote
Old 01-26-2018, 05:38 PM   #2
michael a
michael a's Avatar
Default Re: Thats it for me
Are you 6 or 12 volt and what kind of coil are you using
Sent from my SM-J700T using Tapatalk
michael a is offline   Reply With Quote
Old 01-26-2018, 05:42 PM   #3
Jwilli
Jwilli's Avatar
At least you were prepared. Hope you had a great meal.
Jwilli is offline   Reply With Quote
Old 01-26-2018, 05:44 PM   #4
F.M.
You want it ??, Is FREE in the for sale section !!
F.M. is offline   Reply With Quote
Old 01-26-2018, 11:54 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
Newer is not always better. It is my belief that electronics want and need the cleanest of electrical power. Generators without regulators, bad alternators, old wiring, corroded connections, etc all lend themselves to glitches and voltage spikes that will fry stuff.
Old 01-27-2018, 01:34 AM   #6
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Interesting thought. Maybe that explains why I’ve got 35,000 on my ignition. I have had an electronic regulator since day one as well.? I do go thru and clean connections and grounds every couple of years.
Old 01-27-2018, 09:38 AM   #7
roy green coupe
Recently I was working in our kitchen tiling the floor, my wife walked in with her Samsung tablet to show me a video. I reached over to raise the volume while she was holding it. Well, a big spark from static electricity shot out my finger and that computer was dead as a doornail. Yes indeed electronics can be very sensitive.
roy green coupe is offline   Reply With Quote
Old 01-27-2018, 10:05 AM   #8
denis4x4
denis4x4's Avatar
It would be nice if you posted some details as to your set up so that we can make an educated guess as to why you went through 2 modules. What time period? What brand? What coil? 6 or 12 volts? Never had a failure in 30 plus year that was not self inflicted (twice).
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 01-27-2018, 01:19 PM   #9
Purdy Swoft
Purdy Swoft's Avatar
Too many things can cause complete failure of electronic ignition for my use . I use a mostly original distributor with a Stipe distributor cam , with 10 degrees more dwell . I use a .035 gap at the rotor tip for hotter spark at the plugs . I also recommend a Pertronix 40.000 volt flame thrower coil . Part #40611 . I run 12 volts with a completely unmodified original generator and use a Fun Projects can style voltage regulator . This setup uses original points . I get instant starts and much hotter spark . This setup gives more power that you can actually feel in the seat of your pants. After installing the Flamethrower coil the engine runs so much more efficiently that I had to idle down the carbs . This system looks completely stock and is just as simple as original .
Last edited by Purdy Swoft; 01-27-2018 at 03:24 PM. Reason: added punctuation and a word .
Old 01-27-2018, 04:34 PM   #10
denniskliesen
denniskliesen's Avatar
Purdy, is that the oil or epoxy filled coil?
denniskliesen is offline   Reply With Quote
Old 01-27-2018, 05:30 PM   #11
CarlG
CarlG's Avatar
Epoxy
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
CarlG is online now   Reply With Quote
Old 01-27-2018, 05:31 PM   #12
Purdy Swoft
I'm using the epoxy filled version . 3.0 ohm
Old 01-27-2018, 05:35 PM   #13
Purdy Swoft
Sorry , I got distracted for a while and just now saw the question . Thanks CarlG.
Old 01-27-2018, 06:45 PM   #14
barkleydave
barkleydave's Avatar
No problems with a number of cars and a large boat with twin with Pertronix Ignitors in them.
I do not care what folks are using! Tired of that discussion. I am interested in what caused the fault and failure. We have one in the family car where the module has been in since 1997 perfectly and 40K miles. Clean electrical, 12V alternator 1.4 Ohm coil with external ballast resistor.
So something is causing the problem we would all like to know what it might be.
If using a 12 Volt setup and using a 3.0 ohm coil an external resistor is not used.
barkleydave is offline   Reply With Quote
Old 01-27-2018, 07:09 PM   #15
1wonton
What's a module? I couldn't find one in the parts book.
1wonton is offline   Reply With Quote
Old 01-27-2018, 09:15 PM   #16
F.M.
I think its in the Restoration Guidelines..
Old 01-27-2018, 10:28 PM   #17
Tom Wesenberg
Tom Wesenberg's Avatar
Oh boy!
Now in a week or two we'll be seeing TV lawyers suing the tile company for not having a static electricity warning.
Old 01-28-2018, 08:26 AM   #18
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
We all know that Electronic Ignition is a GOOD thing, but most can FUTZ around with a Test Light & diagnose & fix a STOCK system. If you get your head "straight", fixin' electrical stuff can be FUN!!
Bill Simple
"THE ASSISTANT GURU OF STUFF"
Old 01-28-2018, 10:41 AM   #19
jrelliott
jrelliott's Avatar
Generators are noisy and the DC coming out of them contains spikes as the brushes move from one section of the armature to another. Try looking at this on an oscilloscope and you would be amazed at the signal. That is also one of the reasons a digital voltmeter goes all over the place when measuring voltage when the generator is working. Analog meters dampen out the highs and lows. The battery acts like a LARGE capacitor as it tries to smooth out the output of the generator and get it close to the voltage of the battery. My own theory is that you have some bad connections somewhere that is allowing the generator voltage to get above the electronic ignition module operating voltage.
jrelliott is offline   Reply With Quote
Old 01-28-2018, 10:42 PM   #20
CWPASADENA
CWPASADENA's Avatar
When electronic distributors work, they are great.
However, I use my cars and do not want to be sitting on the side of the road trying to figure out if it is the electronics that died or is it something else.
The original point system is very reliable and works just fine for me.
It is very easy to adjust and trouble shoot if a problem should occur.
However, you can not expect to get good reliability from a worn out stock distributor. Everything must be in good condition to start with.
I also have original pop-out ignition switches which do not work well with most electronic distributors.
Again, this is JUST MY OPINION, others may have different ideas which is fine with me.
Chris W
CWPASADENA is offline   Reply With Quote
Thread Tools
Display Modes
