05-15-2010, 02:30 PM | #1 |
how do I tell if my car originally had a rumbleseat or trunk lid?
Like a lot of model A projects mine is missing the back trunk/rumbleseat lid. I'm also missing the lower back panel. Is there anyway to tell which one would have been original to my car? thanks.
05-15-2010, 02:54 PM | #2 |
Re: how do I tell if my car originally had a rumbleseat or trunk lid?
If it came with a rumble from the factory, the round shaped wedges may still be at the upper corners. They were attached to the quarter panel drip rail with a single screw, and aligned the rumble lid as it just closed, to keep it from scuffing the sides. The latch catch may also still be attached in the center of the upper panel. If it originally had a trunk, maybe one of the trunk hinges would still be installed, in the same upper location, but with two screws.
05-15-2010, 02:59 PM | #3 |
If you have a striker on the top it had a rumble seat. these are Roadster pieces but Coupe are similar
05-15-2010, 04:19 PM | #4 |
I have the round things in the corner. I guess my car had a rumble seat. Cool thanks!
05-15-2010, 04:28 PM | #5 |
05-15-2010, 05:50 PM | #6 |
