05-16-2010, 01:54 PM | #1 |
Rear axel warran keyseat
i have a warran rear axel keyseat and the keyseat in the drum is warren also.what would be a good way too repair it without removing the axel?what about the same problem with the drum?
05-16-2010, 05:30 PM | #2 |
Re: Rear axel warran keyseat
If the drum/hub runs true on the axle, and the axle is not cracked (look close at the keway) make a custom fit key to match the worn keways.
05-16-2010, 06:57 PM | #3 | |
Be sure to torque the axle nuts up good and tight, 125 Ft.Lbs. After you have driven your car for a hundred miles or so, re-torque the axle nuts. This will keep the hub from moving on the axle and wearing the new key and key ways any more. Good luck, Chris Last edited by CWPASADENA; 05-16-2010 at 06:57 PM. Reason: TYPO |
