Old 05-13-2010, 03:16 AM   #1
Ted
Ted's Avatar
Default 29 Gas Tank Leak at Column Bracket
I am wondering what others have used to weld around the steering column support bracket & rivets on a 29 gas tank to stop the leaks. I'm not looking for sloshing compound. I'm wondering about mig welding, brazing, lead-something that will hold up to the stress of grabbing the steering wheel. Thanks.
Ted is offline   Reply With Quote
Old 05-13-2010, 03:29 AM   #2
Rowdy
Default Re: 29 Gas Tank Leak at Column Bracket
They were originally soldered. I resoldered mine after I had it bioled out. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 05-14-2010, 12:21 AM   #3
Mike V. Florida
Mike V. Florida's Avatar
My guess is that if it is leaking the rivits must also be a little bit loose re soldering it would be temporary. I don't know about brazing or welding where it was soldered. Worth a try i guess.
Old 05-14-2010, 12:37 AM   #4
fordcragar
fordcragar's Avatar
My tank is leaking too. It has lifted a lot of paint off of the tank. I was thinking about replacing the tank, but have thought about repairing and maybe putting a sealer inside.
fordcragar is offline   Reply With Quote
Old 05-14-2010, 12:37 AM   #5
Kirby1374
Kirby1374's Avatar
Looks like mine was brazed years ago.
Kirby1374 is offline   Reply With Quote
Old 05-14-2010, 07:34 AM   #6
Barry B./ Ma.
Barry B./ Ma.'s Avatar
I wouldn't do any brazing or anything with a flame. Too dangerous on a gas tank. The originals were soldered. I've had very good results with the epoxy gas tank repair kits from CarQuest. Did one 4 years ago as a temporary fix and it's still holding up well. I would strongly advise changing the support to the 31 style that hangs from the dash and taking the rubber out of the undertank support clamp.
Barry B./ Ma. is offline   Reply With Quote
Old 05-14-2010, 09:35 AM   #7
d.j. moordigian
d.j. moordigian's Avatar
Ted ...I agree with Rowdy, use a radiator shop and then pressure check. Dudley
d.j. moordigian is offline   Reply With Quote
Old 05-15-2010, 10:44 AM   #8
Ted
Ted's Avatar
Rowdy,
What type of solder did you use? Silver solder or plumbing solder?
Old 05-15-2010, 12:00 PM   #9
ford1
every body is worried about getting a flame near the tank so they say solder it, lol, how are you going to solder it with out heat? have the tank cleaned or do it your self by washing it out with tide soap or anythind else you want i use tide soap ,then braze or weld, thats the only way to get a permante fix, if your real nervous fill the tank with water just below where your going to weld, then install the later year bracket the one that attaches to the dash
ford1 is offline   Reply With Quote
Old 05-15-2010, 12:36 PM   #10
Jim Parker Toronto
Jim Parker Toronto's Avatar
Grabbing the steering wheel is a BAD habit that you should try to break. No matter how well it is fixed, you will start the cycle all over again, probably causing more stress and making it worse!
Jim Parker Toronto is offline   Reply With Quote
Old 05-15-2010, 05:55 PM   #11
Ted
Ted's Avatar
I'm guessing that even sitting behind the wheel & steering causes stress on the bracket at the tank.
Old 05-15-2010, 06:19 PM   #12
Chris in CT
Hi Ted, Take your tank to a radiator shop that does gas tank repairs. Have it boiled out, silver-soldered (never weld or braze an A gas tank, the semi-hard sheetmetal will spider-crack from the stress), then coated with a baked-on rubberized internal sealing coating. Highly worth it from a safety and utility service standpoint. Good Luck!
Chris in CT is offline   Reply With Quote
Old 05-15-2010, 08:34 PM   #13
Paul from Maine
Paul from Maine's Avatar
I took mine down to the radiator shop. They soldered it up real well. I'd be careful about welding. Seems I read somewhere the gas tank is heat treated steel or something and welding weakens it. I could be wrong about the heat treatment, but I do remember reading that welding the Model A gas tank was a no-no for some reason.
Paul from Maine is offline   Reply With Quote
Old 05-15-2010, 10:15 PM   #14
Fred K-OR
Fred K-OR's Avatar
I did the radiator shop route with solder. Then got a 30/31 brace to mount it to the upper dash. Brace bolted in with only one hole needed to drill in dash. Send me an email and I can send pictures.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 05-16-2010, 05:50 AM   #15
Ted
Ted's Avatar
Has everyone that has repaired their bracket gone with the 31 style support brace? I was hoping to stay original without the extra brace. Thanks.
Old 05-16-2010, 06:12 AM   #16
Rowdy
I used the solder that my freind at the radiator shop gave me. Same solder he uses on radiators, I am not sure of the exact make up of the solder used. I also used the POR-15 sealer kit. Not much choice on this tank. Rod
Old 05-16-2010, 06:52 AM   #17
Barry B./ Ma.
Ted, my 29 coupe has the 31 brace. It needed a 1/4" spacer plate for mounting and one extra hole. Nothing shows as it's behind the dash rail. The gas tank mount is still in place WITHOUT the rubber sleeve. Don't use both mounts to clamp as it will set up vibration to the tank at the lower clamp.
Old 05-16-2010, 01:25 PM   #18
Fred K-OR
Fred K-OR's Avatar
If you would want to take it out for shows or the like, it is not hard to remove and nothing much would show. It does give the steering column a very good feel.
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 05-16-2010, 01:55 PM   #19
Ted
Ted's Avatar
This has been good information. I had heard of the plating inside the tank & half wondered if the metal would crack as it was heated. I have a spare tank I plan on doing the work to since a radiator shop would end up removing all the paint anyway. This way I can get the spare one ready & remove & replace. Thanks again for all the input.
