Old 10-12-2020, 08:45 PM   #1
hop up
hop up's Avatar
Default Looking for some information on Badger grinding and Babbitt in Wi for 1934 ford block
Looking for some info on Badger grinding and Babbitt . As I believe I have a 33-34 short block that was done by them and never used. This block has been in a heated tool and die shop for 40 plus years and plenty of oil in the air. This would be going into a 33 pheaton and should I find a later motor. Thank you
Wanted flathead speed equipment Thanks
hop up is offline   Reply With Quote
Old 10-12-2020, 09:04 PM   #2
David J
David J's Avatar
Default Re: Looking for some information on Badger grinding and Babbitt in Wi for 1934 ford b
Does it have studs-nuts or bolts that drop in from the valley with nuts holding the main caps on ?
Is there a vent in front valley ?
Is there a raised tower around the fuel pump pushrod bushing ?
Nothing wrong with 33-34 motors IF IN GOOD ORDER !!!!!
David J is offline   Reply With Quote
Old 10-12-2020, 09:15 PM   #3
hop up
hop up's Avatar
David it has nuts holding the mains and dont see the vent by the front valley thank you
Old 10-14-2020, 08:05 AM   #4
hop up
hop up's Avatar
This is the tag on the motor and can see it was rebuilt poured and ground. So know I need to find bearing for the connecting rods . I checked a few places for the parts needed but I couldn’t find any .030 bearing any ideas a source?
Old 10-14-2020, 08:12 AM   #5
deuce lover
deuce lover's Avatar
Try Chuck Kuntz, Barnfind 08(Southside Obsolete) ,Thirdgen Auto, are members here.I found some on EBAY 2 yrs ago but they were .030 +.010.
Old 10-16-2020, 09:20 AM   #6
hop up
hop up's Avatar
Thank you Deuce Lover for the leads
Old 10-16-2020, 11:46 AM   #7
35fordtn
35fordtn's Avatar
Just a thought.. .030" Bearings will cost you a arm and a leg IF you find them. What I did last time, was pulled the crank, had the rod journals spray welded and ground back to Standard. It cost me $220 to have this done and I was able to use Standard sized bearings which are everywhere. Just a thought in case you can;t find any. We may have some .030 +.008" but I am not sure today
Follow Sheldon's advice and check eBay as well..
Old 10-19-2020, 08:21 AM   #8
hop up
hop up's Avatar
Thank you 35fordtn and great idea on the hard chrome spray.
