Old 08-22-2020, 05:39 PM   #1
farmerdick
farmerdick's Avatar
Default Starting the flathead with Chevy Distributor
On 8/10 I started a post on setting up the distributor, and TDC using a Chevy distributor from Bubba. Well I tried starting it up but have spark to the points but nothing at the plugs or coil. The entire ignition system is new. Any ideas? I turned the motor over and did not see any spark at the points even though I could arc them and get a good spark!!!
farmerdick is offline   Reply With Quote
Old 08-22-2020, 06:34 PM   #2
Phil Gillespie
Phil Gillespie's Avatar
Default Re: Starting the flathead with Chevy Distributor
12v or 6v? What coil is in use? Are you using a resistor in the circuit to coil.
You may not need to use this dependant on coil in use. Can check primary coil resistance to verify this.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 08-22-2020, 06:58 PM   #3
40cpe
40cpe's Avatar
I can think of two possibilities of no fire seeing that you have an arc when manually opening the points. (1) Are your points set to where the cam opens them? (2)The rotor is easy to overlook when assembling the distributor.
Old 08-22-2020, 08:30 PM   #4
alanwoodieman
make sure the points /point plate is actually grounded--not just the shaft.
Old 08-23-2020, 06:14 AM   #5
farmerdick
farmerdick's Avatar
I did have a Pentronix Flame Thrower coil with a 1.5 ohm internal resistor(12v by the way). I changed it out for a standard coil for use with external resistor. I wired it up according to the diagram which one wire from +side of coil to I post on voltage regulator then another wire also going from +side of coil to the resistor but that's where i was not sure where the wire went from the other side of the resistor. It looked like it was going to the switch? I will check to see if the plate is grounded. I would not think Bubba would overlook something as important as not grounding the plate.
Old 08-23-2020, 06:45 AM   #6
john in illinois
john in illinois's Avatar
Dick I would suggest a 12V coil that does not use a resistor such as a Bosch blue or NAPA coil. Much simpler. switch to coil, coil to points.
John
Welcome each day
john in illinois is offline   Reply With Quote
Old 08-23-2020, 06:54 AM   #7
farmerdick
farmerdick's Avatar
Goodmorning, John. I am a little dense sometimes What do you mean by switch to coil-coil to points?
Old 08-23-2020, 08:22 AM   #8
john in illinois
Dick, is this for your A V8? If so find the ignition wire from the switch and hook it to + side of coil. - side of coil goes to points.
John
Welcome each day
Old 08-23-2020, 11:22 AM   #9
farmerdick
farmerdick's Avatar
Thank you John. Been away this morning. I will check it after lunch. Also a thank you to everyone in helping me, God knows I need a lot of help.
Old 08-23-2020, 11:30 AM   #10
Krylon32
I'm not to bright but I've had several of these Bubba Distributors with his resistor less coil. My memory is vague but don't you run the ignition wire to the plus side of the coil and the minus side of the coil to the dist?
Krylon32 is offline   Reply With Quote
Old 08-23-2020, 12:57 PM   #11
tubman
tubman's Avatar
It all depends if he has converted to 12 volts (and switched the polarity) or not.
Old 08-23-2020, 01:06 PM   #12
Krylon32
True
Old 08-23-2020, 02:21 PM   #13
JSeery
JSeery's Avatar
If you are using the normal Chevy converted distributor, it is a straight single wiring setup.
With a 1.5 ohm coil, it is Ignition switch to the ballast resistor to the (+) terminal on the coil (sometimes labeled BAT). Then from the (-) coil terminal to the points/condenser (distributer). This coil terminal is sometimes labeled Dist.
With a 3.0 ohm coil, it is Ignition switch to the (+) terminal on the coil. Then from the (-) coil terminal to the Distributer.
The only thing that would be different is if the starter solenoid has the two terminals on the front, one of which is the ballast resistor by-pass during start up. If it has that there is a little difference in the wiring.
Old 08-23-2020, 02:38 PM   #14
Lawson Cox
Lawson Cox's Avatar
Go back to stock and it will crank just fine.
Old 08-23-2020, 06:10 PM   #15
JSeery
JSeery's Avatar
It will crank just fine with a modified Chevy distributor as well, once it is installed and wired up correctly.
