Old 06-27-2020, 02:09 PM   #1
Curtis in MA
Default Manifold/Muffler Joint
Should the connection be solid or have some movement?
Mine moves about a half inch at the bottom and I have tightened the bolts all I can.
Curtis in MA is offline   Reply With Quote
Old 06-27-2020, 02:37 PM   #2
burner31
burner31's Avatar
Default Re: Manifold/Muffler Joint
You need to tighten that up.
Get new clamps/bolts if needed, are you using a sleeve, is the tail pipe flange seating on the manifold correctly?
If it's loose...it's leaking
Keith
Shawnee OK
'31 SW 160-B
Old 06-27-2020, 02:56 PM   #3
Bob C
Do you have the clamp on the right way, there is a top and bottom.
Old 06-27-2020, 03:33 PM   #4
Patrick L.
Patrick L.'s Avatar
Like the fellas said, they're correct.
I cut a gasket from asbestos, well, I guess that stuff is illegal, so I cut up a welding glove. [ it feels, smells, looks and tastes like asbestos]
Old 06-27-2020, 04:12 PM   #5
ryanheacox
ryanheacox's Avatar
I had that same problem. I filed both clamp halves where they meet just a hair and now I have a tight leak free joint.
Old 06-27-2020, 05:08 PM   #6
chrs1961815
chrs1961815's Avatar
Are you using a repro clamp?
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 06-27-2020, 05:28 PM   #7
Werner
Werner's Avatar
N'Abend Curtis,
I use exhaust sealing putty together with the cup ring. If the contact pressure is too low, you must use washers.
Werner
Ford Model A Roadster, 1928
Citroen 11 CV, 1947
Hercules NSU-Wankel Rotary Engine, 1976 (Canadian version)
Werner is offline   Reply With Quote
Old 06-27-2020, 05:50 PM   #8
Curtis in MA
I don't know what is in there. It was put on sometime ago by my father. I just noticed it was loose.
I'll try to take it apart.
Old 06-27-2020, 06:00 PM   #9
WHN
Mikeís has them, they are under $2.00. Looks like asbestos but isnít.
Have used on a couple of Model Aís.
Enjoy.
Old 06-27-2020, 06:37 PM   #10
Ruth
I like the new "no-nut" clamp. Easier to install. Not authentic tho.
Ruth is online now   Reply With Quote
Old 06-27-2020, 06:37 PM   #11
Synchro909
Synchro909's Avatar
I can't imagine that things are any different in the US from here but I use a muffler putty in there to get a good seal, as has been suggested above. It sets hard and to remove it, I use a wire brush in the drill.
BTW, the exhaust clamp is a #$%^ to install on a RHD car. It has to be just right or the clutch pedal won't go down past it. I put a helicoil in one side and use a shorter bolt which means there is no nut for the clutch pedal to hang up on.
Accidents hurt. Safety doesn't.
Old 06-27-2020, 09:54 PM   #12
JoeCB
JoeCB's Avatar
This may be unorthodox but has worked fine for me for many years... wrap a 3/4 " wide band of 4 or 5 folded layers of aluminum foil around the joint. install the clamp over this band and tighten. Of course first ensure a good fit of the pipe flange to the manifold. Never had leaks and the foil stays put and is invisible.
Joe B
JoeCB is offline   Reply With Quote
Old 06-27-2020, 11:07 PM   #13
verdirick
Smile Re: Manifold/Muffler Joint
My suggestion... Buy an Aires muffler. It will have the correct flange that will fit your manifold. AS far as I know it is the only one on the market that is an exact duplicate of the original Ford blueprint.. I've installed one on two A's, Fit and sound are worth the price
verdirick is offline   Reply With Quote
Old 06-29-2020, 09:36 AM   #14
Bob Bidonde
Bob Bidonde's Avatar
The design of the manifold to muffler assembly joint allows for some movement, but not much. It is a semi-ball type joint. The muffler assembly develops a lever bending action on the joint, so it needs to be somewhat flexible and allow some rotational movement of the muffler assembly to dissipate the lever action.
Unfortunately, the design lacks a seal, so we have a habit of over tightening the joint. When the joint prohibits movement, the lever action causes the manifold to bend downward and eventually crack between cylinders 3 & 4.
Bob Bidonde
Old 06-29-2020, 10:01 AM   #15
Ray in La Mesa
Per JoeCB & verdirick, I run an Aries muffler, orange RTV on the joint & wrap it with tinfoil and it works great.
Ray in La Mesa is offline   Reply With Quote
Old 06-29-2020, 09:39 PM   #16
Jerry in Shasta
Jerry in Shasta's Avatar
I took mine to a muffler shop and had the flange bent to a true 45 degress and bend from the flange to the muffler bent to a true 90 degress. Works great with no gasket.
Connoisseur of Rust
Jerry in Shasta is offline   Reply With Quote
Old 06-29-2020, 10:59 PM   #17
vern hodgson
Joe B
Ditto on that
vern hodgson is offline   Reply With Quote
Old 06-29-2020, 11:01 PM   #18
vern hodgson
Originally Posted by vern hodgson View Post
Ditto on that
Position a floor jack under the pipe bend to hold it in position.
Old 06-30-2020, 12:10 PM   #19
Brentwood Bob
Also, besides the jack support, the flange on the exhaust pipe may need some altering with a ball peen hammer, and the end of the manifold filed.
Brentwood Bob is offline   Reply With Quote
