07-09-2015, 05:00 PM | #21 |
Re: Boils over
Pulled the radiator and took it to a radiator shop. They are doing a flow check and whatever other tests they do. Their visual inspection comments indicated they thought the core looked good from the outside.
What is a good indicator the water pump is bad? The newer water pumps had a "seep hole" that pisses water out when the pump is bad.
John from Kapowsin T&A Guy |
07-09-2015, 05:10 PM | #22 |
Re: Boils over
You think you have a waterpump with sealed bearings, so when you spin the shaft the bearings should be quiet, no looseness, and no movement of shaft fore, and aft.
Seals should be good, and running on a smooth clean shaft surface. Depending on what fan blade you are running look for galling, fatique cracks, warping, and balance. Bob |
07-09-2015, 06:41 PM | #23 |
Re: Boils over
Hopefully they don't pressure check with more than 2 or 3 pounds. The A is NOT a pressurized system.
Paul in CT |
07-10-2015, 10:58 AM | #24 | |
Re: Boils over
Coming out around the rad cap. Spark lever is at 50% which is where she runs best. Just MotoMeter at this time. Radiator shop is testing the rad now. I'll go see if the water pump is free wheeling.
07-10-2015, 11:36 AM | #25 |
Re: Boils over
Most 80 year old radiators are plugged, period. If you can't drive 45 mph for 10 min straight without boiling over, you are plugged.
I just ran a test on an unplugged radiator. I ran the engine at 2100 rpm,(45mph), and measured the pressure in the lower hose. I was looking for the low pressure at that point, caused by the pump trying to suck the water out of the core. I got a big fat ZERO. No vacuum at all. A plugged core would restrict flow and cause a vacuum there. I got none. You can conclude from this, that, if the core is not plugged, there is no way the pump can pump too much water. A good core can take all the water the pump can give it. The answer is to rod out the core, but how. Shops will not do it. I'm trying to figure out a way myself. I have two old radiators to play with. |
07-10-2015, 11:47 AM | #26 | |
Re: Boils over
07-10-2015, 12:34 PM | #27 |
Re: Boils over
John,
I had similar issues with my original 29 radiator. It was a function of clogged tubes. If you try the vinegar treatment to break up some of the clogs, you might want to add a gano filter to catch any excess particles that could then go loose and clog other tubes. I wound up changing my radiator for a new one and will eventually have the original one rodded out. Seth |
07-10-2015, 01:16 PM | #28 |
Re: Boils over
Eagle, I just used some clear tubing, held it above the top tank to see how far the level in the tube dropped. It did not move. Earlier, I tried a vacuum gage and thought it was broken when I got zero.
I put a 1/8 in. nipple in the petcock hole and attached the tube to that. I want to do this same thing on a plugged core to see how severe it is. jack |
07-10-2015, 03:40 PM | #29 | |
Re: Boils over
I do not have to "man-handle" the fan to turn it but the belt better be grabbin' pretty good. It always turned "OK" when idling in the barn.
07-10-2015, 04:18 PM | #30 |
Re: Boils over
Just spoke with the radiator shop. My rad is almost totally plugged. They will try to rod it out, otherwise, re-core time.
07-10-2015, 04:27 PM | #31 |
Re: Boils over
Don't be discouraged. This is so common. Put a heavy duty core in if you have to re-core and you will never have to worry about it again.
07-10-2015, 06:26 PM | #32 |
Re: Boils over
John, let us know if they will take it apart and rod it out. The problem is, when they try to remove the top tank, the whole thing comes apart. Most shops know better than to mess with taking off the top tank. Keep us posted. Jack
07-11-2015, 03:09 PM | #33 | |
Re: Boils over
I agree that when I work on my radiator I will remove my bottom tank and use my long thin drill bit to try to clean out the tubes. I'll machine a small knob and use a setscrew to tighten it to the bit, then twist it with my fingers to carefully remove the junk. I've removed the tanks on a couple Studebaker radiators, but haven't removed tanks on any of my Model A radiators yet. |
