Old 02-22-2023, 05:15 PM   #1
mcgarrett
Default Side bowl carburetors - correct identification markings
I have a nice pair of Zenith side bowl carbs for the late '31 Slant Windshield cars with indented firewalls. I'd like to make sure the lower carb bodies (float bowls) are the correct ones for that vintage Model A. What casting numbers, foundry stampings, or other identifying markings should I be looking for to make sure they are correct for the side bowl application? One of them has "Zenith 2" cast into the side of the bowl.
mcgarrett is offline   Reply With Quote
Old 02-22-2023, 05:30 PM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: Side bowl carburetors - correct identification markings
Most parts on those except Zenith 3 which is a side bowl into itself are interchangeable. But there were a few manufacturers even if it says Zenith. I think 3 was made by ford???
It has such cast into the lower bowl. Perhaps someone who builds/knows fine point can be more informative than me!
Oldbluoval is offline   Reply With Quote
Old 02-22-2023, 05:43 PM   #3
mcgarrett
Thanks for your reply. I would like to hear from someone knowledgeable in those carburetors. I'm planning to put them up for sale and want them to be as correct as possible for the next owners. I also noticed that the choke lever is a brass casting and choke driver on one of the carbs is made of brass unlike the usual steel parts. I also wonder if those items are correct for the side bowl units?
Old 02-22-2023, 07:21 PM   #4
Bill Cilker
Bill Cilker's Avatar
The MARC/MAFCA Restoration guidelines and judging standards book (2016 revision) has the information you want to know. Also there has been articles in the Restorer on the subject.
Bill Cilker, Jr
Unrestored 190A Victoria
45B, 160B & 189A
Victoria Association President
Bill Cilker is offline   Reply With Quote
Old 02-22-2023, 08:00 PM   #5
mcgarrett
Bill,
Are these judging guidelines available online?
Thanks for your reply!
Old 02-22-2023, 08:18 PM   #6
Steve Schmauch
You will find answers to your questions if you are able to access the issues of The Restorer magazine for 2017. The Model A Restoration Guidelines and Judging Standards have a good explanation of the external pieces belonging on these carburetors. See Area 1 for all of those details. The Guidelines are not available online.
Steve Schmauch is offline   Reply With Quote
Old 02-22-2023, 08:34 PM   #7
mcgarrett
Thanks, I'll check it out.
Old 02-24-2023, 02:32 PM   #8
Steve Schmauch
The 2017 issues of The Restorer have the details for identifying all Zenith and Ford carburetors. Issues of The Restorer from Nov-Dec 2022 through May-June 2023 have/will have all of the details for identifying all Holley carburetors used in production of the Model A.
