12-14-2012, 12:08 PM | #1 |
Model T hood repair Hinges
Has anyone attempted to repair the hinge mechanism(s) on a 1926 Roadster? The sheet metal is prone to tearing at the hinges and I am attempting to redo this but looking for advice in the meantime.
12-14-2012, 12:14 PM | #2 |
Re: Model T hood repair Hinges
Do you need a repair or a restoration? Id personally take a cut off wheel and remove all the old hinge folds, and then fasten a length of chrome plated piano hinge in its place.
Put the two halves on the car into position for marking. Mine was cracked only at both ends, so I pop riveted a piece of sheet metal over (under) the area... maybe 1" x 1". My hoods' a POS tho with no sides... ws
" Warning; the following contains content that the anal retentive may find offensive - please skip on to the next posting!" Last edited by yachtsmanbill; 12-14-2012 at 12:21 PM. |
12-14-2012, 05:55 PM | #3 |
I have done a few where I use a combination of TIG welding and strategic metal replacement where it needs it. I restore as much of the original metal as possible. They look new afterwards and have lasted for years.
Best, Paul |
12-14-2012, 08:20 PM | #4 |
" Warning; the following contains content that the anal retentive may find offensive - please skip on to the next posting!" |
