02-07-2024, 09:42 AM | #1 |
Intake Manifold gasket material - 1950 V8
We just had to remove the intake manifold and want to replace the gasket. What was on there looks like it was metal(?), but I am finding paper gasket replacements. What should I be looking for?
Thanks. |
02-07-2024, 10:58 AM | #2 | |
Re: Intake Manifold gasket material - 1950 V8
I have always used paper gaskets, lightly greased prior to installation.
I went, I saw, I bought the T shirt 51 Ford Deluxe Tudor 32 Ford roadster 39 Mercury Towncar |
02-07-2024, 12:03 PM | #3 |
I've never seen a metal one.
02-07-2024, 06:14 PM | #4 |
Some manufacturers use a sandwich type gasket due to the heat riser area in the block.
02-16-2024, 09:54 AM | #5 |
I just started pulling off the old gasket and it is definitely metal. Seems to be a paper-metal-paper sandwich, and it looks pretty old. The indications on the gasket were "MADE-IN-USA", "FEL-PRO", and "8903".
Our replacement is paper only, and that seems to be all that is available. Searching Fel-Pro, I find "MS 8903" and that looks to be paper also. |
02-16-2024, 10:55 AM | #6 |
"It don't take but country smarts to solve the problem" (Smokey Yunick) '41 Merc Town Sedan / 260" 8CM engine '66 Fairlane four door / "warmed up" 302 |
