Old 11-25-2021, 10:46 PM   #1
PeteVS
PeteVS's Avatar
Default Banjo rear end lube capacity?
How much 600 WT oil should I put into my Model A rear?
Thanks!
Old 11-25-2021, 11:07 PM   #2
bruceincam
bruceincam's Avatar
Default Re: Banjo rear end lube capacity?
1.5 pints
bruceincam is offline   Reply With Quote
Old 11-25-2021, 11:25 PM   #3
Model A Ron
Model A Ron's Avatar
Fill it till it runs out....As for 600 I am not a fan and would rather use synthetic 90w140
Model A Ron is offline   Reply With Quote
Old 11-26-2021, 09:32 AM   #4
chrs1961815
chrs1961815's Avatar
Keep in mind that the original 600w oil is not made. Whatever is being marketed as 600w is some kind of modern synthetic oil.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 11-27-2021, 09:46 AM   #5
burner31
burner31's Avatar
Think of it like pouring a beer into a glass, you fill it to the very rim
Yes, I'm Irish/Scottish
Keith
Shawnee OK
'31 SW 160-B
Old 11-27-2021, 09:56 PM   #6
ETAModel
Thanks!
How much? Until it runs out, as Dad would say.
ETAModel is offline   Reply With Quote
Old 11-29-2021, 11:31 PM   #7
PeteVS
PeteVS's Avatar
Thanks folks! I had recently seen that if a trans were filled too high (to the plug) that there might be foaming which could lead to problems. I'll see if I can fill it to slightly below the plug, measuring to see how much it takes to do that.
(This is for my "avatar picture" project car but I can't post pictures of it here for fear of being run out of town.)
