Old 01-29-2023, 01:29 PM   #1
Kingo
Default 1930 town sedan hole in cowl…what attached here?
On a 1930 Murray Town Sedan, what was attached to this hole in the front door opening of the cowl?
File Type: jpg D730D41B-2B92-4620-ADEA-B08704D5835A.jpg (33.4 KB, 213 views)
Kingo is offline   Reply With Quote
Old 02-04-2023, 09:59 AM   #2
Dick Carne
Dick Carne's Avatar
Default Re: 1930 town sedan hole in cowl…what attached here?
I would guess possibly a wood screw, but not certain. I am in the process of restoring a '29 Murray Fordor for my daughter and her family, so I will look the next time that I am over at their place to compare cowl sections. Obviously the Briggs and Murray bodies are different, as the Murray bodied fordors had indentions in the floor sills at this point (the lack of a bead on the bottom of the doors did not require the Briggs bodies to have the indentation. I'm curious as well if anyone has a more definitive response.
Dick Carne is offline   Reply With Quote
Old 02-04-2023, 10:05 AM   #3
Kingo
It’s a conundrum for sure. I don’t know what the wood screws would attach to since the floor rail doesn’t come into contact with that hole, unless a separate piece of “filler “ wood was used.
Old 02-04-2023, 10:58 AM   #4
mcgarrett
I'm guessing a body drain?
mcgarrett is offline   Reply With Quote
Old 02-04-2023, 12:24 PM   #5
JayJay
I have those same holes in my unrestored '30 Murray Town Sedan, both sides. Nothing in them. I suspect they may have been part of the manufacturing process, maybe a locator hole for a dowel in the press that formed that pillar.
JayJay
JayJay
San Francisco Bay Area
1931 Briggs S/W Town Sedan
JayJay is offline   Reply With Quote
Old 02-04-2023, 03:28 PM   #6
MAG
MAG's Avatar
On coupe and probably Tudor and pickup bodies. the sill at the bottom of the door opening is riveted to the cowl in that hole.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 02-04-2023, 07:57 PM   #7
jb-ob
Building on MAG's observations, could Ford have supplied the cowls to Briggs & Murray.....everything from the cowl back being individual to the body builder ??
Wondering ??
jb-ob is offline   Reply With Quote
Old 02-04-2023, 09:56 PM   #8
JayJay
Wondering ??
A reasonable conclusion given what is laid out here. But I'm not going to lose a bunch of sleep over a couple of open holes in my A-pillar.
JayJay
JayJay
Old 02-04-2023, 10:47 PM   #9
J Franklin
J Franklin's Avatar
A good place for a rubber bumper.
