Old 09-22-2019, 01:21 PM   #1
burner31
burner31's Avatar
Default White crap in carb bowl - Pic
Anyone know what the white crap is inside my carb bowl?
I drive this car almost everyday, only run pure gas, none of that corn garbage.
started running real bad, this is what I found.
Last time carb was taken apart was maybe six months ago.
Clean it all out, chased all the channels/holes and it's running 100% better now.
Keith
Shawnee OK
'31 SW 160-B
Old 09-22-2019, 02:04 PM   #2
Jeff/Illinois
Jeff/Illinois's Avatar
Default Re: White crap in carb bowl - Pic
Keith my first thought before reading your post was 'Ethanol' but you are running pure gasoline and driving the car regularly so it's not sitting a lot, sure looks like old gas/water contamination but that must not be the case.
Years ago a friend with a Chevy Blazer running Ethanol when it first reared it's ugly head had the same gooey white junk in his carburetor.
Interesting. I'm anxious to see what others say
Old 09-22-2019, 02:05 PM   #3
Y-Blockhead
Y-Blockhead's Avatar
Looks like you may be getting water in your gas, causing corrosion. I use Sea Foam in my gas to absorb any 'moisture'.
Old 09-22-2019, 02:21 PM   #4
Werner
Werner's Avatar
Hallo Keith,
this looks like zinc alcoholates. These are caused by fuels containing alcohol.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 09-22-2019, 04:26 PM   #5
burner31
burner31's Avatar
Interesting about the ethanol/alcohol comments.
That was my thought also...but I never buy that for my older cars.
I usually get my gas at Walmart, they have pure gas in one pump and 10% ethanol in the other, of course the pure gas costs more.
And remember, this is Walmart, and who's to say that both pumps don't pump from the same tank...how would we ever know?
File Type: jpg betty_boop_gas_station_by_zagzagel.jpg (138.9 KB, 100 views)
Keith
Shawnee OK
'31 SW 160-B
Old 09-22-2019, 05:10 PM   #6
jb-ob
Been there, seen that.
I supposed it was our 'modern gas' not getting along with a zinc carburetor.
Maybe not in your case but possibly modern formulated gasoline attacking pervious gas tank sealers (sloshing compounds).
Unless the gasoline is color tinted (like kerosene), how would you know you received pure gas or something else by mistake.
JB
jb-ob is offline   Reply With Quote
Old 09-22-2019, 05:32 PM   #7
Blue-Truck-Nut
Blue-Truck-Nut's Avatar
I've seen that also, I have an old loader that used to routinely do the same thing. I was running alcohol free gas also. Tank was getting water from somewhere. The drip edge on the hood was dripping on the tank vent. Resolved that problem, and drain the carb when I park it for more than a couple days.
Sent from my E6810 using Tapatalk
Blue-Truck-Nut is offline   Reply With Quote
Old 09-23-2019, 12:50 AM   #8
Werner
Werner's Avatar
I use allways a little cup "Marvel's Mystery Oil" in the fuel tank. And never take gasoline with ethanol.
Werner
Citroen 11 CV, 1947
Old 09-23-2019, 11:01 AM   #9
rotorwrench
rotorwrench's Avatar
Tilotson's would be vulnerable to corrosion. The cast iron one's would have a different form of corrosion but they are all vulnerable to modern fuels in one way or another.
Old 09-23-2019, 11:27 AM   #10
Farrell In Vancouver
Farrell In Vancouver's Avatar
Any chance your fuel tank has had a sealer installed? I once tried a tank sealer by the name of Kreem and it did not like the gasoline started to pollute the fuel system with a similar looking white goo
Farrell In Vancouver is offline   Reply With Quote
Old 09-23-2019, 06:17 PM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
Does the gas pump send both crap gas and better gas through the same hose?
This will always give you some crap gas, as that was also my first thought for the white crap.
MMO is good stuff, and I always use it in all my old cars and small engines, along with the non corn crap gas.
Old 09-24-2019, 12:22 AM   #12
Werner
Werner's Avatar
Please tell me, what is gas with corn bagage?
Werner
Citroen 11 CV, 1947
Old 09-24-2019, 01:56 AM   #13
Y-Blockhead
Ethanol...
Old 09-24-2019, 06:44 AM   #14
Fhane
Fhane's Avatar
Try taking a sample of your gas in a glass jar. Add a small amount of water to the jar. Let the jar sat for a few hours. If alcohol is present you will see phase separation.
Fhane is offline   Reply With Quote
Old 09-24-2019, 08:49 AM   #15
burner31
burner31's Avatar
No tank sealer, and I'll give the gas in a jar test a try.
Corn gas comes from a different pump then the pure.
I've been using the MMO at each fill up.
The only way I can think of water getting into the tank is when I wash the car.
Keith
Shawnee OK
'31 SW 160-B
Old 09-24-2019, 10:57 AM   #16
Fred A
Fred A's Avatar
I'd like to blame the Corn Belt for jamming us with their ethanol but here in California the ruling party finds ways to increase cost of using a car, evidenced by the fuel being at least a dollar more than others. My old cars with zinc carbs usually look worse than those of the OP. My two-stroke tools use real gasoline with the oil pre-mixed and look like new. Good Luck: Fred A
Fred A is offline   Reply With Quote
Old 09-24-2019, 06:02 PM   #17
TerryH
TerryH's Avatar
There are thousands of Model A’s in California, and all have no choice but to use the ethanol gas. I would prefer regular gas, but after 13 years of using the so-called “crap gas” I have had zero problems with it, and don’t know of any other A owners with issues either. Apparently it is selective where it really harms Model A’s......
TerryH is offline   Reply With Quote
