Old 12-20-2020, 08:50 AM   #1
WRA
WRA's Avatar
Default 1933/34 Ford Running Board Brackets
How do you tell the difference between the original and reproduction running board brackets.
Were they marked FORD, or with part # etc.
Thanks
WRA is offline   Reply With Quote
Old 12-20-2020, 09:18 AM   #2
STAN WHITE
Default Re: 1933/34 Ford Running Board Brackets
The original brackets are made from heavier material. Stan
STAN WHITE is offline   Reply With Quote
Old 12-20-2020, 11:14 AM   #3
DavidG
DavidG's Avatar
The originals were bare of Ford script and part number so no guidance there. Likely the wraparound to create the bolt hole on the end isn't formed as well as on the originals.
DavidG is online now   Reply With Quote
Old 12-20-2020, 03:10 PM   #4
johnboy34
My originals are .095 or 13 gauge and have numbers stamped into them.
File Type: jpg imgonline-com-ua-resize-GpyKmDHIFA09.jpg (44.3 KB, 111 views)
johnboy34 is offline   Reply With Quote
Old 12-20-2020, 05:33 PM   #5
DavidG
DavidG's Avatar
Unusual, and the non-zero digit seems to correspond with the Ford part numbers (40-16485, 16486, 16487). My several sets of them have no markings.
Old 12-20-2020, 06:05 PM   #6
mercman from oz
mercman from oz's Avatar
Thanks for the picture showing the Numbers.
Old 12-20-2020, 06:08 PM   #7
johnboy34
They are from this car, bought new in Tekeo, Washington. The pair with "70" stamp goes in the rear. Notice the bend in the other pair, they match the curve of the frame. "50"on the right and "60" on the left.
File Type: jpg imgonline-com-ua-resize-fhO4WGP7LHc0.jpg (21.4 KB, 21 views)
