11-14-2017, 02:52 PM | #1 |
Mitchell Syncro Tranmission.
There were a few reports concerning Mitchell syncro transmissions having excessive noise, hopefully not a serious problem, any further developments?.
Nothing can be made foolproof, ---- fools are ingenious bastards. |
11-14-2017, 04:40 PM | #2 |
Re: Mitchell Syncro Tranmission.
While it is a great idea I have no trouble driving my stock Model A transmission. Double clutching is simple, and for me, automatic.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
11-14-2017, 04:45 PM | #3 |
I have 2 cars with standard gearboxes and 1 with the Mitchell. I can't say there is much difference between them noisewise. All I hear with either is the musical whine you would expect with spur gears.
I think anybody who complains about the noise from either has unrealistic expectations.
11-14-2017, 08:00 PM | #4 |
Mitchell doesn't "run them in" as they build them. At first they will be noisy as the new gears get to know each other. Most people expect that and some are surprised by it but all is well. The noise will subside by the end of your first tour and it will sound very familiar minus the clashing of teeth while shifting by the uninitiated (new bride, whatever) I don't see a lot of them on the secondary market, so Sue and Co. must be doing something right.
11-14-2017, 09:15 PM | #5 |
I have the Mitchell tranny, no unusual noise.
11-14-2017, 09:35 PM | #6 |
"whatever works!" |
11-16-2017, 10:13 AM | #7 |
The original and Mitchell Snychro Transmissions are both subject to new defective roller bearings.
Please see the conclusion at the end of this post: https://www.fordbarn.com/forum/showt...81#post1531281 |
12-28-2017, 08:48 AM | #8 |
How can a Mitchell syncro be identified visually?
John |
12-28-2017, 09:10 AM | #9 |
I installed one a month ago. No noticeable difference in noise level. Only real difference was the shift throw distance vs the original. VERY SATISIFIED!
12-28-2017, 09:22 AM | #10 |
Aside from the synchro, the most enjoyable feature is having a second gear set that is 26 % higher.
12-28-2017, 09:28 AM | #11 |
Mitchell Model A transmissions use a stock Model A case and top so there will be no out side sign of what is inside it. We have supplied a good number of cases to them.
12-28-2017, 10:07 AM | #12 | |
12-28-2017, 07:14 PM | #13 | |
I have 13 K miles on my Mitchell and except for the problem with leaks in the earlier transmissions that Mitchell made, it has been excellent. I would definitely NOT go back to an original transmission. My experience, Chris W. Last edited by CWPASADENA; 12-31-2017 at 12:45 AM. Reason: CORRECTED ERROR |
12-28-2017, 07:56 PM | #14 |
I just got ours,haven't had time to put it in yet.My wife can drive a stick but not too good at double clutching. Didn't think our marriage was going to survive me trying to teach her.I have been debating whether to change to a 3.54 gear while I have it a part. I would like to cruise at about 50 mph, right now about 45 is a comfortable rpm. I expect it to drive much different with the higher first and second so maybe I should try just trans swap first ?
12-29-2017, 07:51 PM | #15 |
A 3.54 R & P should work good with the Mitchell transmission. The higher second gear will help out the big step between second and high.
I installed a 3.54 R & P in my Vicky when I rebuilt the rear end. I still have a bone stock engine and transmission. The engine struggles a bit with the big step between second and high but after I upgrade the engine and install a Mitchell transmission (hopefully sometime this next year) things should be much better. My opinion, Chris W. |
12-29-2017, 08:56 PM | #16 |
It's like the whine of cars, in an Old British Movie & the cars ALWAYS trail a little EXHAUST SMOKE! "Maybe" STP isn't sold there?---LOL
Bill Grosspolluter
12-30-2017, 08:37 AM | #17 | |
12-30-2017, 11:12 PM | #18 | |
Mitchell will make the synchro transmission with the stock 1st gear and a 15% higher 2nd gear. THAT is the way to go. With stock 1st and 15% higher second, it puts the spacing between all 3 gears about the same 'distance' apart. No more big gap between 2nd and 3rd. |
12-31-2017, 12:43 AM | #19 |
The car I use for touring is a '30 Tudor which is fairly light. I am running a "B" engine with a 5.5 head and a 3.78 R & P. and 19 in wheels. I also have a Mitchell O.D. in it.
I have the 15% Low and 15 % second. It works very well. Taking off from a dead stop is no problem. The car I have the 3.54 R & P in is a Victoria which is heavier than the Tudor. When I install a Mitchell Transmission, I will stick with the stock Low but a 15 % Second. I feel the Vicky with the 3.54 needs a little more low gear than the Tudor with a 3.78. With the original transmission, the step between low and second is not the problem, it is the big step between second and high that needs help. Mu opinion, Chris W. |
12-31-2017, 07:05 AM | #20 |
Thanks for your info, P.S. and C.W. Sounds like I will have a nice driver if I just do the trans.Since mostly we just cruise around on back roads most times we have enough speed, but there are times when we feel like we are in every bodies way. Just can't get around the need for that overdrive , guess that can be a future plan.Happy New Year everyone. Roy
