Old 12-13-2015, 04:39 AM   #1
WRA
WRA's Avatar
Default 1934 Ford Driveshaft Pin Installation
How do you secure the pin in the driveshaft on a 34 Rearend. The rear end was an original and two, very worn short pins came out when I broke it down. only replacements I see are long pins, but I don't see how you secure them. Do you use a mallet and mushroom one end, or is there some trick or part I'm missing. Here is a link to the pin I'm using.
http://www.macsautoparts.com/ford_me...passenger.html
WRA is offline   Reply With Quote
Old 12-13-2015, 07:27 AM   #2
Terry,OH
Terry,OH's Avatar
Default Re: 1934 Ford Driveshaft Pin Installation
They are mild steel, if the pin is too long cut it to the length you need. Support the area under the pin (so as not to do any damage to bearings) and you can hammer the end even using center punches to mushroom it out, or use a 1/4-20 grade 8 long bolt (no threads in the coupler) and install a lock nut. Do make sure the U-joint is lubed properly so the shaft can slide in and out.
Old 12-13-2015, 09:06 AM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
There may be a very good reason why that pin was in pieces, and before you put another in place by peening the one end, make sure you know why the original failed. What I found on my '35 fordor, when that pin had failed, was excessive wear of the splines of both the pinion and the female coupling welded into the end of the drive shaft. Your failure could have been caused by a similar wear situation, or possibly something else has gone wrong. IMHO, I would suggest checking things over very carefully to find out what caused the original failure before putting a new pin in place and putting everything back together.
John
Old 12-13-2015, 06:52 PM   #4
Talkwrench
Talkwrench's Avatar
As with the above posts. Just be careful not to keep hammering / peeing the end over the more you hit it the finer it will splay out and you don't want those bits cracking off and going back into the diff.
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
