Old 03-29-2014, 12:12 PM   #1
Steve H.
Default Gas Line Leak
Gas line leak between carburetor and fuel pump. How to prevent leaks at nuts and farrels? Have tried soldering and crimping. Any suggestions?
Steve H. is offline   Reply With Quote
Old 03-29-2014, 12:40 PM   #2
jrhaelig
jrhaelig's Avatar
Default Re: Gas Line Leak
I think the alignment on these fittings needs to be spot on.
I had a little trouble, but some re-bending of the line made it leak free
John Haelig
Bridgewater, NJ
1939 Ford Pickup
1963 Lincoln Continental
1939 Buick
jrhaelig is offline   Reply With Quote
Old 03-29-2014, 12:49 PM   #3
tiger.1000
Steve I always soften the olives on the pipes by annealing them first. Gives them a better chance to seal. Always works for me.
tiger.1000 is offline   Reply With Quote
Old 03-29-2014, 04:34 PM   #4
G.M.
I think some companies have made the ferrules out of hard brass and they won't compress to form a seal. Like Tiger said heat them up with a soft flame and put in cold water to soften them. G.M.
www.fordcollector.com
Old 03-29-2014, 07:25 PM   #5
Graeme / New Zealand
Graeme / New Zealand's Avatar
Try realigning first as jrhaelig suggests. I had exactly the same problem. I took the pipe off again and carefully and slowly did the nuts up...no leaks.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 04-01-2014, 10:30 PM   #6
ronford
I have seen the fuel line fitting wrapped with sewing thread to stop a leak
at the fitting.
ronford
ronford is offline   Reply With Quote
Old 04-01-2014, 10:41 PM   #7
ford38v8
ford38v8's Avatar
at the fitting.
ronford
??????? April fool, right ????????
Alan
