07-21-2013, 10:18 PM | #1 |
1940 gas line
Refurbished gas tank and new gas line. I've tightened the brass nut on gas line as tight as I can, still getting a little seepage, ruined paint. I'm sick about it. Everything installed. Any suggestions.
Thanks |
07-22-2013, 12:44 AM | #2 |
Re: 1940 gas line
Which joint is leaking,tank,line to flex line,flex line to pump,pump toshort gas line,or carb line to carb ???? ken ct.
07-22-2013, 07:57 AM | #3 |
Re: 1940 gas line
Sounds like a bad ferrule on the end of the tube. Some of the ferrules were made of hard brass and are very hard to compress. You could heat the ferrules with a long soft flame and quinch in cold water. This anneals them. G.M.
www.fordcollector.com |
07-22-2013, 09:23 AM | #4 |
Re: 1940 gas line
It's the brass nut going into the gas tank. Wondering if there's sealer you know of. Thanks.
07-22-2013, 10:28 AM | #5 |
Re: 1940 gas line
Permatex #80062 for gasoline. Also SEAL-ALL.
I dig coal, which provides motivation for EVs. |
07-22-2013, 10:37 AM | #6 |
Re: 1940 gas line
07-22-2013, 02:11 PM | #7 |
Re: 1940 gas line
Steve same ferule problem on the tank end. G.M.
07-22-2013, 03:37 PM | #8 |
Re: 1940 gas line
It sounds like you don't have a ferrule on the line and then the correct Ford nut.
