07-13-2020, 05:34 PM | #1 |
Head Torque question
When using a crows foot on a short extension, or one of the torque tools sold to torque the nut slightly under/back of the distributor on the head, can anyone advise if using one of those tools changes the torque value or reading for that particular nut??
Bob from Northport Northport, Michigan |
07-13-2020, 05:38 PM | #2 |
Re: Head Torque question
A normal crows foot won't change it enough to worry about.
07-13-2020, 05:40 PM | #3 |
Because the vertical force-axle ist the thame, there is no missreading
of the torque.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
07-13-2020, 05:42 PM | #4 |
I use turn to torque,if the others take a quarter turn to check,then that one gets a quarter turn..offset leverage is miniscule,reduce wrench setting by a few pounds
07-13-2020, 05:58 PM | #5 |
The C shaped tool, no change. My tool will not fit the water neck nuts, I use a deep socket.
With one hand I steady the tool and pull with the other.
07-14-2020, 08:13 PM | #6 |
