06-28-2020, 05:23 PM | #1 |
59 a Crankshaft front seal
If fitting the new type seal and sleeve to crankshaft is it necessary to then shorten up the back end of the double pulley to allow for the fitting of seal and sleeve?
Thanks, Phil NZ |
06-28-2020, 06:29 PM | #2 |
Re: 59 a Crankshaft front seal
Phil, I used one on my 59 and did not have to make any adjustments to the pulleys.
06-28-2020, 06:41 PM | #3 |
Phil what sleeve are you going to use. 59AB doesn’t use a sleeve. 8BA use a sleeve. Not really sure what sleeve your going to use.
06-28-2020, 06:45 PM | #4 | |
You'll be happy with the one piece seal!! |
06-28-2020, 06:47 PM | #5 |
one brand is a speedi-sleeve, thin ss, been used in industrial pumps for years and yes not cheap
06-28-2020, 06:56 PM | #6 |
06-28-2020, 07:07 PM | #7 |
what year engine are you putting it on? I shortened a 40 pully to put on an 8ba so I could mount the crankshaft fan
06-28-2020, 07:12 PM | #8 |
Alan his title for thread says 59AB
06-28-2020, 07:13 PM | #9 |
Ok just checked a couple of measurements.
The supplied bush that seal runs on is 1.08" long. Length from back edge of pulley to end of bush is 1.0" in length. Dont have the C/shaft here to cross check. But would think perhaps the pulley would need to have the 1" removed off the back to accomodate the length of supplied bush to ensure pulley alignment with w/pumps and Genr. Or just stick with the rope seal ! and forget about modification. Phil NZ |
06-28-2020, 07:14 PM | #10 |
06-28-2020, 07:31 PM | #11 |
Sounds like you're using the late 49-53 sleeve with it . . . is it one that is smooth (for the new seal). If so, then you'd need to trim the back of the 59x pulley to account for the sleeve length. What I can't say is if they made it the correct length. If it was me, I'd get a late 49-53 pulley that used the same type of slip-on sleeve and determine the length from the front of the pulley (where the big washer hits it) - to the back where it would hit the sleeve - to determine the length you need.
06-28-2020, 07:45 PM | #12 | |
Phil NZ. |
06-29-2020, 12:24 AM | #13 |
Trying to cut off an early 8BA and some of the 59AB pulleys is not a perfect solution since diameter a bit into the bore is bigger so the pulley doesn´t center perfectly after cutting.
I prefer speedy sleeves for that reason. |
06-29-2020, 07:50 AM | #14 |
If the sealing surface is in good shape, the one piece seal will work just fine on the 59 pulley. I've done it many times with no leakage problems. The small grooves are not a problem.
06-29-2020, 08:52 AM | #15 | |
Could even double up on front seal and also use the "rope seal" Phil NZ |
06-29-2020, 08:57 AM | #16 |
06-29-2020, 02:12 PM | #17 | |
I imagine it could be machined off and then use the non-spiraled sleeve with the 1-pc seal?? Never done it this way but it does make sense? If you do happen to use the neoprene seal you should remove it from it's rubber carrier and get some silicone sealer behind it. Lessens the chance of any leak. Thanks, Gary in N.Y. P.S. Here's a few shots of the parts including the 1-pc seals, the correct sleeves (non-spiraled and spiraled) and the crank pulley from the 59A!
http://www.stromberg-bulletin.com/me...berg-equipped/ |
06-29-2020, 03:55 PM | #18 | |
No leaks after the "operation" in both cases.....might just have been lucky. |
06-29-2020, 08:22 PM | #19 |
If the rope seal works with the spirals, why wouldn't the neoprene?
06-30-2020, 10:27 AM | #20 |
