Old 05-02-2020, 08:33 PM   #1
Phil Gillespie
Phil Gillespie's Avatar
Default Uncle Max Stromberg 97 Tool
Have a tool from Uncle Max purchased some time ago to clear accelerator jets.
Just finished checking a " rebuilt carb" and beside leaking float needle,idle jets
jets and PV replacing I also found accelerator jet passage blocked on one side.
Treated it with brake cleaner then used the 'Tool" which screws into PV recess.
Soon had this sorted and cleared. Carb is now ready for use and leak free.
Endorse this great tool for Stromberg carbs.
Thanks Uncle Max.
Phil NZ
Phil Gillespie is offline   Reply With Quote
