04-17-2020, 05:12 PM | #1 |
What’s this?
Thanks Andy 1952 F1 |
04-17-2020, 05:45 PM | #2 |
Re: What’s this?
Looks like a flat head with dual spark plugs.
04-17-2020, 06:35 PM | #3 |
Re: What’s this?
Elco Twin Spark Plug Cylinder Heads (1939 to 1948)
// Elco Twin Spark Plug Cylinder Heads (1939 to 1948) Primarily designed for use on 1939 to 1948 Ford flathead V8 engines. May also be used on 1949 to 1953 Ford flathead V8 engines, subject to minor modification. One of the best flowing flathead V8 cylinder heads ever produced! ELCO cylinder heads require the use of a Vertex style angle drive to accommodate a 1929 to 1941 Nash Twin 8 Distributor for ignition purposes. Ford 8BA flathead front timing cover may also be used. Please inquire for details. Compression ratio: 8.25 to 1.
04-17-2020, 06:45 PM | #4 |
Re: What’s this?
Wow, Pete thanks!
Now that’s pretty cool.
04-17-2020, 08:25 PM | #5 |
Re: What’s this?
Andy....You better have that Nash 16-pole distributor in your hands before you go dropping big bucks on a pair of those heads, 'cuz those Nash dizzies are even harder to find than soft lips on a chicken. DD |
04-17-2020, 09:31 PM | #6 |
Re: What’s this?
04-17-2020, 09:53 PM | #7 |
Re: What’s this?
From the H.A.M.B. > https://www.jalopyjournal.com/forum/...heads.1033377/
Elco Heads Member from Melbourne Australia Dual Plug Flathead V8 V Twin Distributor Timing Cover This conversion enables you to use two distributors / magnetos to fire Dual plug Flathead V8's. These V Twin timing covers have been fitted to the engine in the photo's and test run. These are made from a high quality alloy and are heat treated. They come fully machined and ready to bolt on to your engine. We also have the Electronic ignition kit for this set up also, please enquire for details. Price is US $350.00 plus postage to anywhere in the world.
04-18-2020, 06:52 AM | #8 | |
Re: What’s this?
Stay healthy!
04-18-2020, 06:56 AM | #9 |
Re: What’s this?
What's this ? Answer : the coolest flathead i've ever seen !
THANKS !!!!!! Fun stuf ! |
