Old 01-11-2020, 05:11 PM   #1
adileo
adileo's Avatar
Default Sanity check
39 coupe
2.5 pints for tranny (drain & fill)
2.5 pints for rear (drain & fill)
The reason asking volume/capacity is to insure I have enough GL4
GL4 85/90 weight tranny
GL5 for rear - tractor supply can’t recall weight probably 85/90
Thanks
Andy
1952 F1
adileo is offline   Reply With Quote
Old 01-11-2020, 08:24 PM   #2
paul2748
paul2748's Avatar
Default Re: Sanity check
Can't you use the GL4 for the rear?
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 01-12-2020, 06:58 AM   #3
adileo
adileo's Avatar
GL4 I have to order online. Not available in stores around my area.
Thanks
Andy
1952 F1
