Old 01-06-2011, 04:31 PM   #1
Safari bob
Lightbulb Phaeton Saddle Plug
In looking through Henry's Lady, there is a description in the phaeton section that says when the top is up, the saddle for the top mechanism is removed and a plug is inserted to close the hole that the shaft went through. What is the plug made of? When can a set be purchased? THanks.
Bob Moore
Safari bob is offline   Reply With Quote
Old 01-06-2011, 05:37 PM   #2
pooch
pooch's Avatar
Default Re: Phaeton Saddle Plug
I had original grommets on my AR to fill the hole.
pooch is offline   Reply With Quote
Old 01-06-2011, 06:02 PM   #3
Bob-A
Bob-A's Avatar
When I had my '29 phaeton I went to the local hardware and got some plastic plugs that fit. Never could find any original or repop "authentic" plugs. Most of the time I just left the saddles attached.
Bob-A
Bob-A is offline   Reply With Quote
Old 01-06-2011, 06:13 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
I've been looking for those rubber plugs also and can't find any. Metro rubber is close to me and next time I drive by their store I'll have to see if they have them or would be willing to make a run of them. I would need a sample (or blueprint) to show them, if they would make a run.
Old 01-06-2011, 06:22 PM   #5
wrndln
I thought someone posted a message fairly recently stating they found that house heating duct plugs fit well (used when the ducts are cleaned to plug the holes). I may have been dreaming, but I am pretty sure I saw the post within the last 3 or 4 weeks. I a have not tried anything to plug the holes on my phaeton, but it may be worth a try.
Old 01-06-2011, 06:31 PM   #6
peters180a/170b
peters180a/170b's Avatar
I have seen on cars using metal Plug buttons that you can buy at a good hardware store.Some i see use electic box metal plugs and paint them body color.. I made mine for the 180A , which are chrome plated.[ and very rare] I have seen only 1 pair and know of only 1 pair !!!!!
peters180a/170b is offline   Reply With Quote
Old 01-06-2011, 09:26 PM   #7
pooch
pooch's Avatar
This is off my Canadian june 28 AR.
I would dare say, they are original.
Topside
Underside
Profile
Old 01-06-2011, 10:41 PM   #8
barnstuf
I have a 1929 Phaeton purchased from the original owner who was very proud that he had never folded the top. In my 56 years of owning I have never folded the top. The body plugs are an almost flat metal plug and both are still in place.
barnstuf is offline   Reply With Quote
Old 01-07-2011, 02:25 PM   #9
Tom Wesenberg
Topside
Underside
Profile
Pooch can you post or send me the dimensions of the plug, so I have something to show the guys at the rubber plant. Is the inside concave? Thanks
Diameter of outside dome..............
Diameter of inside lip....................
Height from table to top of dome....
Height from table to edge of dome..
Old 01-07-2011, 02:53 PM   #10
pooch
pooch's Avatar
Tom, give me your address, I will post the plug to you.
Old 01-07-2011, 07:14 PM   #11
Safari bob
Thanks to all of you on the saddle shaft plugs you use for your cars. I have many suggestions on how to proceed. A good hardware store should have what it takes. I usually leave the saddle on, but the shaft is nothing special, so a plug will be great. Just need to make certain that I always have the saddles with me in case of rain. Thanks again.
Old 01-08-2011, 12:23 AM   #12
Tom Wesenberg
When it rains, the top goes up and the saddles aren't used. I'm guessing you meant plugs rather than saddles.
Old 01-08-2011, 12:27 AM   #13
pooch
pooch's Avatar
Safari Bob, and I know Tom has an original AR too.
Could you check where the shaft comes out of your body holes?
Mine come out towards the front.
Looking at the left side, it looks like this.
If others are not in the middle, same as mine, it would be great when Tom gets my sample and gets some made, he could get some with offset holes in them.
The body/shaft needs a grommet there not just for appearance, but also for stopping water getting in.
If a holed grommet could have the original edge dome profile, it would be a great bit of gear.
Old 01-09-2011, 04:48 PM   #14
Ron Geer
Bob Moore- Try Restoration Specialties & Supply,Inc. Phone No. 814-467- 9282 and ask for Dave Mihalko Jr.. I sent Dave an original rubber plug some time ago to make a mold and make the plugs. His first run of plugs were not domed like the original and he is supposed to have reworked his mold and produced some more plugs. Ron Geer.
Ron Geer is offline   Reply With Quote
