Old 04-15-2013, 02:37 AM   #1
RUNNERBUN
RUNNERBUN's Avatar
Default Another Shocky Question
I'll start another thread so as not to hijack 29er's thread. I have had my Model A on the road for quite some time now and it is used on a very regular basis. I have run up in excess of 70000 (Seventy Thousand) miles since restoration. All this mileage has been done without Shocks, and before anyone jumps on me and tells me what a fool I've been I must add that it had always been my intention to put them on. There has certainly been many times when I wished that I had them on and told myself that I'm not taking it out again untill I have fitted the shocks.
My question is. Does driving without Shocks have an adverse effect on tyre wear, and if so what?
Adjust your points with gentle blows of a 2 pound hammer
RUNNERBUN is offline   Reply With Quote
Old 04-15-2013, 05:25 AM   #2
QGolden
QGolden's Avatar
Default Re: Another Shocky Question
I have tried to sort through that question lots of times. Although one could make an argument that excessive bounce could stress tires and contribute to their wear, all i have ever seen is anecdotal evidence of this. Even if you look at some of the Shock Mfgrs Websites, they will list tire wear as a symptom of bad shocks, but do not offer a reason why the two are correlated. With Struts that is a different story. But to me, on an A, Shocks are bounce dampeners and have no measurable effect on tire wear.
It's not what people think they know that will hurt them, it is what they think they know that aint so! -Mark Twain.
It is the very things that we think we know, that keep us from learning what we should know.- Unknown
QGolden is offline   Reply With Quote
Old 04-15-2013, 05:38 AM   #3
spike
how about spring bushings and extra wear on them? And also the springs?
spike is offline   Reply With Quote
Old 04-15-2013, 12:01 PM   #4
Hicktick
Hicktick's Avatar
Driving without shocks puts a lot of strain on the frame .
The more flex , the more frame cracks and sags .
Hicktick is offline   Reply With Quote
Old 04-15-2013, 12:22 PM   #5
QGolden
QGolden's Avatar
Spike, Hicktick, yup, that and a lot more, could dangerous on curves, bottoming out springs, breaking springs, difficult to maintain control over northern New England frost heaves, lots of good reasons to have them, but the question was pertaining to tire wear. I have never seen a direct connection to tire wear and lack of/or bad shocks.
Old 04-15-2013, 12:38 PM   #6
Hicktick
Hicktick's Avatar
Shocks are designed to keep the tire on the pavement .
If the tire can bounce it will wear quicker .
If the tire remains in constant contact with the road , and just rolls it wears better .
Think of skimming a rock across water ??
Old 04-15-2013, 01:15 PM   #7
Kevin in NJ
I know you can get cupping with bad shocks.
Tire wear reasons
But, the large amount of un-sprung weight in the Model A suspension means you will have other effects. There is a certain dampening from the mass that will yield different effects. The chart on the website is for modern cars with their low unsprung weight.
My experience says that you likely have not enough spring effect in your system. The drivability issues stem from too much undamped spring effect. No rebound from poor springs then there is less need for shocks.
I know from experience that a 31 coupe and a 30 town sedan with known good front springs are very uncomfortable to hold on the road above 25 MPH. With shocks the cars are dreams over 60 MPH. Others report the same findings.
I also know all the guys with no shock and no bounce issues have obvious spring issues. They also do not drive their cars over 45 and probably do not have brakes safe for 30 MPH- but that is a whole other thing.
So I am not telling you that you are wrong. I can only relate personal experience. If you were to drive a properly restored car that has good springs and shocks you might get a different opinion of your car and make a few more changes then you expected.
Kevin in NJ is offline   Reply With Quote
Old 04-15-2013, 11:41 PM   #8
columbiA
My 30 coupe without front shocks is comfortable to drive at 60 in OD with easy steering & good brakes.
columbiA is offline   Reply With Quote
