Old 09-18-2020, 06:01 PM   #1
Gezer
Gezer's Avatar
Thumbs down spark plug wire set
I need a spark plug wire set for a 51 EAB flat head engine.
Engine is stock but has Petronic electronic ignition. 6volt, poss. ground.
Petronic said the wires should be surpression and or carbon core type to avoid issues with the ignition down the road.
Gezer is offline   Reply With Quote
Old 09-18-2020, 06:23 PM   #2
19Fordy
19Fordy's Avatar
Default Re: spark plug wire set
I use this Taylor spark 8MM Spiro Wound plug wire kit for my 8BA Pertronix ignition. They work great since 1999. Do not use any solid copper wire core plug wires on any electronic ignition. You cut the wires to length you need. Also buy the crimping tool. Go to Taylor website , Summit or Jegs. Plus, hot rod shops in your area might carry them.
https://www.ebay.com/itm/28319450096...SABEgIm2PD_BwE
19Fordy is online now   Reply With Quote
Old 09-18-2020, 09:00 PM   #3
tubman
tubman's Avatar
I will second the recommendation on a special spark plug crimper. Until I got one, the spark plug wires I made were second rate.
Old 09-18-2020, 10:43 PM   #4
40cpe
40cpe's Avatar
This week I put these MSD wires on my 8BA. They are 8mm spiral wound stainless wire rated at 500 ohms/ft, same as some of the low resistance Pertronix wires. I ordered mine last week for $30 and free shipping, now they are about $46. Go figure.
https://www.amazon.com/MSD-5554-Stre.../dp/B001BDUTJ2
40cpe is online now   Reply With Quote
Old 09-19-2020, 02:40 AM   #5
51 MERC-CT
51 MERC-CT's Avatar
If you are not interested in wire that is colored or has graphics then Pertonix spiral wound (PN 708190) is the stock looking, stock diameter, 7MM wire that I used.
https://www.ebay.com/itm/Pertronix-7...Cclp%3A2334524
Old 09-19-2020, 06:37 AM   #6
V8 Bob
V8 Bob's Avatar
I'm also using these wires.
Old 09-19-2020, 08:57 AM   #7
GaryU.
GaryU.'s Avatar
Just put a Rajah brand crimper on the swap side. The price is right, FREE!!
GaryU. is offline   Reply With Quote
Old 09-19-2020, 09:26 AM   #8
GaryU.
GaryU.'s Avatar
Went fast, tool no longer available. Sorry to other members that sent a PM.
Old 09-19-2020, 12:42 PM   #9
19Fordy
19Fordy's Avatar
I used this. May take seconds to load. You can also get them in plastic.
https://www.jegs.com/i/Taylor/895/43395/10002/-1
Old 09-19-2020, 01:46 PM   #10
tubman
tubman's Avatar
Did you read the reviews on the Jeg's site about this? They are all "one star". It seems to be universally disliked.
Old 09-19-2020, 03:53 PM   #11
flatjack9
flatjack9's Avatar
I get my plug wires from Speedway. They have a universal 7mm set for around $35- $40, suppressor style.
Old 09-19-2020, 04:03 PM   #12
1948F-1Pickup
1948F-1Pickup's Avatar
Black 8mm Taylor Street Thunder on my flathead.
Used the Summit wire crimp tool.
http://www.taylorvertex.com/product-...4052643&sID=46
https://www.summitracing.com/parts/sum-900399
1948F-1Pickup is offline   Reply With Quote
