Old 11-21-2017, 01:16 PM   #1
FrankWest
FrankWest's Avatar
Default Stromberg 40 carb vs Stromberg 48 Carb
Which Stromberg Carb was used on a 1934 ford v8?
FrankWest is offline   Reply With Quote
Old 11-21-2017, 01:51 PM   #2
Anteek29
Anteek29's Avatar
Default Re: Stromberg 40 carb vs Stromberg 48 Carb
I, too, would like to see a reference (chart) showing which carbs were used on what
early Ford V-8s!
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 11-21-2017, 02:24 PM   #3
Steve Staysko
Steve Staysko's Avatar
The Stromberg 48 Carburetors were the original-equipment carburetors for the 1934 Ford Flathead V-8s and the 1935. The 97s were offered on the 85hp V-8s from 1936 to early 1938.
Steve Staysko is offline   Reply With Quote
Old 11-21-2017, 02:29 PM   #4
FrankWest
FrankWest's Avatar
I heard that the Stromberg 48 carb in 1935 actually had a 48 stamped into its case. But the Stromberg carb 48 in 1934 had NO 48 stamped on its case.
Old 11-21-2017, 02:34 PM   #5
Steve Staysko
The Stromberg 48 carburetor on my 34 Roadster has no 48 stamped on the case.
Old 11-21-2017, 05:40 PM   #6
uncle max
uncle max's Avatar
A lot of what appear to be model 48's are actually model 40 carbs.
The "40" designation came from the Ford part number prefix for 1934 automobiles. The 40's are very similar to 48's with the exception of the upper idle channel circuits. Outwardly, it's near impossible to tell the difference.
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 11-21-2017, 05:43 PM   #7
Charlie ny
Frank and I have been discussing this issue. There is a Stromberg model 40 which is
basically on the outside like a 48 only without the 48 stamped on the RH rear corner
of the air horn and bowl OR in raised letters on the drivers side air horn and
bowl. Here is what you don't see.......the model 40 has a slightly different idle circuit
than the 48. This circuit is not a big deal but that is what really separates the model
40 from the 48. Model 40 is correct for '34. Something else to consider........40 is the
prefix for everything strictly '33 and '34............48 is the prefix for everything strictly
'35. In my stash I probably have 25 model 48 bowls with NO stamped or raised 48
showing.
Like lots of Henry's stuff......a conundrum !
Charlie ny
Charlie ny is offline   Reply With Quote
Old 11-21-2017, 08:21 PM   #8
FrankWest
FrankWest's Avatar
So, If I have a stromberg 48 with no stamping designating 48 then it is most likely a Stromberg 40?
Old 11-21-2017, 08:43 PM   #9
Barn Junk
Barn Junk's Avatar
I agree Charlie. Here are some some Stromberg casting codes I have noted from my tear downs.
Model 40. Bowl = P-19401 , Air horn = P-19402
Model 48, Bowl = P-20671 , Air horn = P-20692
These different #s from Model 97s
Barn Junk is offline   Reply With Quote
Old 11-21-2017, 09:08 PM   #10
Charlie ny
Frank.....The deciding issue between the 40 and 48 ,to be painfully detailed, is the idle circuit. If you remove the air horn from your carb and you observe air channels leading
up to the idle tubes you have a 48. If you observe no air channels you have a 40.
No model 40 had model numbers however model 48's might have raised #48s on the
left side or stamped 48's on the right side or no #'s at all.
Charlie ny
Externally only a couple guys can tell the difference between a 40 and 48
Old 11-21-2017, 10:41 PM   #11
Keystone 34 3w
Keystone 34 3w's Avatar
Unlike the 48, doesn't the 40 not have the S/W lever on the side?
Keystone 34 3w is offline   Reply With Quote
Old 11-21-2017, 10:51 PM   #12
Keystone 34 3w
Old 11-22-2017, 01:14 AM   #13
koates
The 40 and 48 do not have the summer/winter positions on the throttle shaft for the accelerator pump rod. The model 97 has this feature which was used in 1936. Regards, Kevin.
koates is offline   Reply With Quote
