11-06-2022, 06:35 PM | #1 |
Steering housing leak
Overhauled and adjusted my steering several years ago. Everything is great concerning the steering except I have a small leak I would like to address. I can not remember if I put an accessory oil retaining tube in my box when I overhauled it. I would like to check and add one if omitted, if I can do this without removing the steering assembly from the car. I do not have any other issues with the steering and it only marks it's spot. I would still like to check it out. If it requires removal of the column, I'll just periodically add fluid.
11-06-2022, 07:06 PM | #2 |
Re: Steering housing leak
You can do it without removing the box. Easy to do.
11-07-2022, 06:55 AM | #3 |
