12-13-2011, 02:57 PM | #1 |
1942-1947 half ton I.D. HELP!
I recently purchased the front section of a '42-'47 half ton (back of cab forward) and I am trying (unsuccessfully) to identify it. The person that I bought it from claimed it was a '41 but with parallel leaf spring's he's clearly wrong! V.I.N. tag's in both the inside of glove box and on the firewall are unreadable. Behind the front crossmember on top of left frame rail reads 699C-77080, with stars stamped at both ends and the dash has arrow heads on both ends. Can anybody give me any info?
12-13-2011, 03:03 PM | #2 |
Re: 1942-1947 half ton I.D. HELP!
The serial number is for a '46 1/2 ton pickup I believe and the front end is definitely '42-'46.
Paul J. |
12-13-2011, 03:16 PM | #3 |
Thank you svm99, I couldn't find any place to check the numbers. We'll go with '46 then...
12-14-2011, 07:41 PM | #4 |
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford |
