Old 09-22-2023, 05:32 PM   #1
mercury 48
Question 1946-48 Ford and Mercury Convertible sequence to install door glass and vent window?
For a 1946-1948 Ford and Mercury Convertible model, what is the sequence to reinstall the vent window assembly and the door glass assembly please?
Is the sequence installing the vent window assembly first and then installing the door glass assembly second?
Or do you install the door glass assembly first and then the vent window assembly second?
Do you have any tips on what is the easiest way to install these please?
Thank you
mercury 48 is offline   Reply With Quote
Old 09-23-2023, 05:53 AM   #2
flathead48
Default Re: 1946-48 Ford and Mercury Convertible sequence to install door glass and vent wind
I installed the vent window assembly first, no tighten anything to everything is installed & adjusted.
flathead48 is offline   Reply With Quote
