04-24-2012, 01:56 PM | #1 |
two 2's air cleaner
does anyone make a single air cleaner for two 2's? '38 motor, offy intake, 2 strombergs. like an oval one?
04-24-2012, 02:16 PM | #2 |
Re: two 2's air cleaner
Theres those thickston ones
04-24-2012, 03:07 PM | #3 |
never heard of them were are they available/
04-24-2012, 03:18 PM | #4 |
Check out O'Brien Trucker's. Sure to have something you are looking for.
04-24-2012, 03:41 PM | #5 |
I had a twin carb unit from motor city that I sold a month ago as I replaced it with a Hexagon tool air cleaner. I can't think of the company but they are out in california, I believe that they make another style without the name. As soon as my old brain can remember I will re post it.
04-24-2012, 03:49 PM | #6 |
Vintage speed web-site has pictures of the two that I am aware of (I don't know if he has them available though). They can be made to fit most dual manifolds. Last edited by rotorwrench; 04-24-2012 at 03:57 PM. |
04-24-2012, 04:28 PM | #7 |
got mine from retro rod inc , they have some others two!
04-24-2012, 04:35 PM | #8 | |
Dayum - that motor's PURDY!! |
04-24-2012, 04:47 PM | #9 |
Thanks! Gets lots of coments from fellow Flathead lovers with the hexagon intake, now with the air cleaner it should really be cool looking. The motor is a bit lonely now though with the car getting ready for a new paint job
04-24-2012, 06:42 PM | #10 |
Charlie Price in Florida use to sell a remake of the Edmunds cleaner for the close fitting carbs. I think his business is Vintage Speed.
04-24-2012, 08:40 PM | #11 | |
Tom What is the color code for the gold you use for the engine. I love the look of the engine I am planning to paint mine the same. There are so many type of gold hard to decide. Thanks Frenchy |
04-25-2012, 08:31 AM | #12 |
Hey Frenchy, The gold color is from Pasti-cote #223 universal gold. Got mine from the Car Quest store in stone. I like the color also, good luck!
04-25-2012, 09:00 AM | #13 |
That would be Plasti-Kote, sorry can't type!
04-25-2012, 09:56 AM | #14 |
O'Brien over on the HAMB casts a big oval one that is basically a blank canvas for what you need...it can be drilled for whatever carb spacing you have. It is meant to be used with the little hotrod filters hidden inside, not a good idea IMHO, but it is big enough for some adapting to a real aircleaner. KN has a size chart of filters so you could hunt either a big oval one or two single ones big enough not to work as chokes.
04-25-2012, 10:22 AM | #15 |
Jan,
Why would you hide those wonderful carbs under one big hat? |
04-25-2012, 02:18 PM | #16 |
Mike, you convinced me. and from what i've seen, i looks like the carbs just breath in the hot air comming off the intake, from the bottom of the cleaner. i didn't see any that were open on the sides.thet the cleaner element is exposed.
04-25-2012, 02:29 PM | #17 | |
Just cut the number of holes in the bottom that you require. |
04-25-2012, 03:32 PM | #18 |
PETE, thats what i was looking for. the sides open for good breathing, and i want to get away from these small elements.
04-25-2012, 04:44 PM | #19 |
Here's a K&N dimensonal chart: http://www.knfilters.com/search/universal.aspx
Pick a filter, build a can. I would also go through the site and try to find OEM application of the chosen filter, just in case you need to find a replacement at the K-Mart in East Overshoe. |
04-25-2012, 04:46 PM | #20 |
