11-21-2023, 06:15 AM | #1 |
crown wheel carrier
Is there a difference between the crown wheel and spider carriers of 9-34 and 10-37 gear sets. I have just disassembled my Roadster diff, which had 9-34 gears fitted, but also had .062" side to side movement clearance between the crown wheel and pinion. The speedo drive has 10-37 on the housing, so does not match the gear set. There were other things wrong with it, but want to make sure I use the correct carrier assembly for a 9-34 gear set.
11-21-2023, 09:49 AM | #2 |
Re: crown wheel carrier
