Old 09-21-2020, 09:11 PM   #1
W1964
Default Installing inside door panel & handle/crank
On a 39 Ford there two pyramid shaped, compression springs that go between the door frame and the inside door panel. These springs are necessary to install the inside handle and the window crank. My question concerns the springs. Is the large end placed against the door frame or against the inside door panel? Thanks a lot for your response.
W1964 is offline   Reply With Quote
Old 09-22-2020, 05:36 AM   #2
51 MERC-CT
51 MERC-CT's Avatar
Default Re: Installing inside door panel & handle/crank
Large end against the door panel.
