06-26-2015, 06:25 AM | #1 |
Radiator caps
I read on here once - I think - an old flathead boy said never screw down the radiator cap down tight - run it with the cap loose - and have the fluid level up to the coils only.
Thoughts.
4 doors are better than no doors! |
06-26-2015, 06:34 AM | #2 |
Re: Radiator caps
The thought behind that may have been to not build up any pressure in a old weak radiator.
06-26-2015, 06:34 AM | #3 |
Re: Radiator caps
The radiator should be filled up to the filler neck, 22 quarts and the cap should be tight. If you loose water you have a problem that needs to be fixed. The radiators all have over flow tubes. G.M
www.fordcollector.com |
06-26-2015, 11:47 AM | #4 |
Re: Radiator caps
Do you think millions of V8 Fords came with the cap left loose? Duh!
06-26-2015, 12:04 PM | #5 |
Re: Radiator caps
The radiator usually will find its' own level. Well mine does anyway & that is down from the top & above the tubes. I run Skips pumps & check valve on my 36LB engine.
06-26-2015, 12:15 PM | #6 |
Re: Radiator caps
06-26-2015, 01:03 PM | #7 |
Re: Radiator caps
Been running my 8BA with no pressure since 1950 and never overheated once. I remove the lower seal on the cap and use an overflow tank, so my rad is always full to the top. I do have to add coolant occasionally. Not very often.
06-26-2015, 02:18 PM | #8 | |
Re: Radiator caps
Mine is a EAB ('52 Customline) - got it last Nov and I think it's still trying to find its comfort level. Since I don't drive it very far I've wondered if it would be best to not run a pressured system. I'm installing a overflow tank right now as a precaution.
4 doors are better than no doors! Last edited by Blu Dice; 06-26-2015 at 04:52 PM. |
06-26-2015, 03:50 PM | #9 |
Re: Radiator caps
B-O-B, do u have the large top tank on ur radiator?
06-26-2015, 04:32 PM | #10 |
Re: Radiator caps
On the subject of radiator caps, my new walker radiator ( for 32 Ford with flathead) came with a 7 lb cap, is this too much? I've always been told it should be 4 lb.
06-26-2015, 05:07 PM | #11 |
Re: Radiator caps
Run what they sent you. You got ten years warranty.
06-26-2015, 07:28 PM | #12 | |
Re: Radiator caps
06-26-2015, 09:45 PM | #13 |
Re: Radiator caps
06-27-2015, 06:27 AM | #14 |
Re: Radiator caps
For what reason did you decided to do this - this is in a '48 Ford right?
06-27-2015, 07:31 AM | #15 |
Re: Radiator caps
4t8v8 do you have a picture of your set up? I really like to see how you have it - Thx.
06-27-2015, 01:24 PM | #16 |
Re: Radiator caps
I installed a small, inexpensive coolant recovery tank (purchased from O’Reilly’s) inside the engine bay. I ran a long hose from the radiator overflow to the tank. The overflow will collect in the tank and, when the engine cools, it is sucked back into the radiator. The radiator cap seals well and keeps the system “closed” which allows me to keep the radiator full. If needed, I add coolant to the overflow tank. I have this setup for about 12 years on ’36.
Kerry |
06-27-2015, 09:06 PM | #17 |
Re: Radiator caps
Your car came from factory with a 4lb. pressure cap. I would put it back to factory specs. and let water find it's own level. If it doesn't overheat drive it and enjoy.
06-28-2015, 11:04 PM | #18 |
Re: Radiator caps
I am not set up for pictures. Sorry. I mounted the tank to the front of the left inner fender, cut the overflow tube shorter and ran a hose from it to the tank. Pretty simple, really. Works just as 6lucky13 described. Been on there for about 10 years. Found the S10 tank on EPAY.
