06-28-2015, 12:24 PM | #41 |
Re: My lights went out!
06-28-2015, 12:29 PM | #42 |
Before you dig into that light switch make sure the battery is disconnected otherwise sparks might happen.
Dwayne |
06-28-2015, 12:37 PM | #43 |
06-28-2015, 12:40 PM | #44 | |
Tried to pull the switch "switch shell down, won't go down more that 1 inch. No familiar with what I am looking at? |
06-29-2015, 05:40 AM | #45 |
After you lower the bail, the lower portion of the switch is removed by gently pulling it down. You can then check for continuity on all of the leads with a volt/ohm meter. That is where your problem will be.
06-29-2015, 10:18 AM | #46 |
