06-22-2015, 01:58 PM | #1 |
Is this normal?
When I drive my 50' 3spd, no overdrive, possible it was removed IDK
I notice when I let off on the gas it feels like in goes into neutral. Feels like it's in overdrive, but i don't have it. I noticed because my old 54' did it when it was in overdrive. It's like there is no back pressure when releasing the gas pedal. Is this normal?
Really, I'm Trying |
06-22-2015, 02:12 PM | #2 |
Re: Is this normal?
I would say it is NOT normal for a non-overdrive transmission to freewheel. The standard transmission does not have the sprag clutch in it to allow it. The only explanation I can think of is the throttle sticking and continuing to drive the car.
06-22-2015, 02:27 PM | #3 |
Re: Is this normal?
I'm not a transmission expert, so this might be a silly question, could it have had an overdrive and then removed at some time and this could be why it's driving this way?
The throttle is working properly, no sticking. When you let off the throttle it just feels like it's gliding in neutral.
06-22-2015, 02:35 PM | #4 |
Re: Is this normal?
Does it do this while in 1st gear also?
Alan |
06-22-2015, 02:35 PM | #5 |
Re: Is this normal?
Hey Captain, Take a look underneath, someone could have put an OD tranny in it and never installed electrical components or cable to enable/disable it. Lever on transmission could be in free wheel position. Just a thought.
Howard |
06-22-2015, 02:45 PM | #6 | |
Re: Is this normal?
"Ford38v8" yes it does it in 1st gear.
06-22-2015, 04:06 PM | #7 |
Re: Is this normal?
Sounds like a previous owner had trouble with the OD and took the controls off thinking that was all they had to do. I bet it IS an OD trans, especially since it does it in 1st gear. A non OD might jump out of 2nd or 3rd into neutral if very worn but not 1st.
06-22-2015, 04:47 PM | #8 | |
Re: Is this normal?
I going to pull the inspection cover and see if there is a lever still mounted for OD and If there is I will try move it back in opposite direction. It's acting just like the OD in engaged.
06-22-2015, 08:16 PM | #9 |
Re: Is this normal?
Why pull an inspection plate?? Just go under and look!
06-22-2015, 08:26 PM | #10 |
Re: Is this normal?
It's eaiser to pull the cover, 2 bolts holding on right now, floor is still bare metal. I'm old and have a bad back.
06-28-2015, 06:45 PM | #11 |
Re: Is this normal?
Well upon further inspection I found the lock lever for the OD on back side of transmission, moved lever forward and drove it. It was in overdrive all the time and now it's disengaged. Don't know if it's original trans or like you said, just replaced with OD transmission and no components for OD. Thanks much.
Really, I'm Trying Last edited by captaintaytay; 06-28-2015 at 07:38 PM. |
06-28-2015, 11:18 PM | #12 |
Re: Is this normal?
I would try to get it to work
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
06-28-2015, 11:58 PM | #13 |
Re: Is this normal?
Actually, Captaintaytay, It was not in overdrive the whole time. Without the electric controls working it was in direct, but the one-way sprag was letting it freewheel because it could not shift into O/D. Moving the lockout lever merely locks up the sprag so it can't freewheel (nor could it shift into overdrive even if the electric controls were working).
06-29-2015, 08:02 AM | #14 |
Re: Is this normal?
Get the OD working, you'll love it.
06-29-2015, 09:49 AM | #15 | |
Re: Is this normal?
And yes I would definitely like to have a functional OD. Everything is missing to make it work.
