Old 02-06-2024, 03:23 PM   #1
Noswal
Default Ignition switch rekey
Any locksmiths on the forum? I have a 1954 Customline that I need the ignition switch changed to fit my key. Thanks.
Butch
Noswal is offline   Reply With Quote
Old 02-06-2024, 04:35 PM   #2
paul2748
paul2748's Avatar
Default Re: Ignition switch rekey
A local locksmith should be able to help you. I had a local locksmith do key work on my 56 Bird.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 02-06-2024, 07:06 PM   #3
Noswal
Called every locksmith in my area. They concentrate in reprograming FOB's, unlockong doors and residential stuff. Each one said this is too old for them to fool with.
Old 02-06-2024, 07:39 PM   #4
5851a
So key fits doors but not ignition?
5851a is offline   Reply With Quote
Old 02-06-2024, 09:25 PM   #5
Abe Lugo
I would first get new ignition key set if you need to keep it a running driver.
As far as rekeying, it seems to be a lost art. Basically you need to find locksmith that specializes in this sort of thing, it will be pricey.
essentially on the tumbler there is a little steel cover, it holds down the pins and about 6 springs. each pin as an upper an a lower. the correspond to the position, if they are match correctly to your key, once the key is in, you unlock it.
I have to do this same thing because I want 1 key for the lock and ignition, but someone broke the ignition on F100. At some point someone did the old stick a screwdriver and broke out all the pins. but my replacement obviously key doens't work my old keys and I
also want mine to match up.
I reached out to a lock parts guy on ebay to see what diameter these are
https://www.ebay.com/itm/325205509361
you can see all the parts are there, you just have to be crafty in taking part your tumbler and matching your key.
Also guys as easy as this seems, it has become a very lost art to do. A locksmiths in LA are just key cutters like hte OP says. I once was quoted 100's to rekey a Cadillac lock. On those they just pull a number and cut a key for 35.00. I can imagine what actual rekey pin work would cost.
Also there is a locksmith on ebay that sells refurbished car lock sets with new keys, I'll see if I can find them.
here they are, maybe do a contact seller
https://www.ebay.com/sch/i.html?_ssn....m3561.l161211
Abe Lugo is offline   Reply With Quote
Old 02-06-2024, 09:46 PM   #6
51504bat
51504bat's Avatar
32phil here on the Barn. Lots of good reviews
Old 02-07-2024, 08:09 AM   #7
GLAmes
GLAmes's Avatar
This shop made keys for my trunk and ignition. https://www.beltonlocksmith254.com/
'54 Skyliner. Restoration in progress.
GLAmes is offline   Reply With Quote
Old 02-07-2024, 08:57 AM   #8
32phil
I can re pin and cut keys for most Ford locks up to 1964.
Contact me after April 1st and I should be able to help.
845 551 5132
Phil
Early Ford Lock & Key Service
http://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
Old 02-07-2024, 09:19 AM   #9
Ford blue blood
Ford blue blood's Avatar
The right hand door lock cylinder has the key code stamped on it. It should be the same for the ignition cylinder unless it was changed out in it's previous life.
Bill, certified Ford nut.
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 02-09-2024, 09:32 AM   #10
Noswal
Thanks everybody. I'll contact 32phil. Hopefully he can help.
Old 02-16-2024, 03:26 PM   #11
Zeke3
Zeke3's Avatar
Another person you can contact is FlatheadCoupe (aka John Mclure), he may be able to help sooner than April 1st.
Zeke3 is offline   Reply With Quote
Old 02-20-2024, 06:19 PM   #12
orangedog
orangedog's Avatar
Abe Lugo, Thanks for the ebay links. My drivers door lock broke last week in my 54. I was able to order door lock assemblies and ignition cylinder keyed the same.
orangedog is offline   Reply With Quote
